I am trying to install Ubuntu on a laptop, that won't boot Windows, it always just asks for reboot. So I decided to install Ubuntu instead and get rid of windows entirely. I started the installation and chose something else for partitioning. I configured the root, swap and home partition and then, when I'm finished a message appears:
"The partition table format in use on your disks normally requires you to
create a separate partition for boot loader code. This partitionshould be
marked for use as an "EFI boot Partition" and should be at least 35 MB in
size. Note that this is not hte same as a partition mounted on /boot."
What I tried, is to make an EFI partition exactly as suggested on this site: https://help.ubuntu.com/community/DiskSpace . However, the message kept appearing.
How should I proceed if I want to erase everything and leave just the new Ubuntu? Thanks for any suggestions.
David
  • 111
