How do I install java, ant, and red5 on Ubuntu 14.04. All I see is Ubuntu 12.04, which doesn't work. Redhat tutorials do not work. UBUNTU 12.04 TUTORIALS DO NOT WORK!!!!
http://linuxadminzone.com/quickly-install-java-ant-ivy-and-red5-flash-server-in-linux/ Google is your friend. It took 2 minutes to find the answer
David
  • 3,487
GUS
I found packages for all of them, so I assume just apt-get installing the packages should work:
sudo apt-get install ant openjdk-7-jdk red5-server libtomcat6-java icedtea-7-plugin
The command works for me. I have ubuntu 14.04, and on my system red5-server depends on :
shackle@shackle-desktop:~$ apt-cache depends red5-server
red5-server
Depends: adduser
 |Depends: default-jre-headless
  Depends: <java6-runtime-headless>
    openjdk-6-jre-headless
    openjdk-7-jre-headless
    oracle-java6-installer
    oracle-java7-installer
    oracle-java8-installer
    oracle-java9-installer
    sun-java6-jre
  Depends: libred5-java
  Depends: libtomcat6-java
  Conflicts: <red5>
It includes libtomcat6-java but not libtomcat7-java.
The answers to Unable to correct problems, you have held broken packages might be helpful.
Perhaps :
dpkg --get-selections | grep hold
to see list of held packages
sudo apt-get remove <packagesfromabove>
then
sudo apt-get update
then retry the command above.
Open terminal and run the following commands:
sudo apt-get update
To install java:
   `java -version`
(If it returns "The program java can be found in the following packages", Java hasn't been installed yet, so execute the following command:)
sudo apt-get install default-jre
sudo apt-get install default-jdk
Reference here
Install ant:
To install red5:
apt-get install -y red5-server
(Here you may get some dependency problem like:
The following packages have unmet dependencies: red5-server : Depends: libtomcat6-java (>= 6.0.20-7) but it is not going to be installed E: Unable to correct problems, you have held broken packages. ) then use the command
sudo apt-get install libtomcat6-java
to start red5:
service red5-server start
refrence here
Ravan
  • 9,567
this is bug with Red5 in Ubuntu version 14.04 reported here. it is working with lower version. you can do manual installation that will work . i have tested it on Ubuntu 14.04.
For installation of red5 follow steps of my another answer here
other packages you can install with apt-get
pl_rock
  • 11,715
