48
What does rm -rf do when used to remove files or directories?
How do the -r and -f options work together?
TellMeWhy
  • 17,964
  • 41
  • 100
  • 142
5 Answers5
73
The command rm -rf is the same as rm -r -f.
From rm's man page (type man rm in a terminal to see it) -r does:
remove directories and their contents recursively
And -f does:
ignore nonexistent files and arguments, never prompt
So in combination they do both.
In fact it is a very dangerous command because it will recursively remove everything within the directory you choose (or just remove the file you choose), and it will do so without ever prompting you.
Please use this command with care!
28
In addition to the previous correct answer, I would like to teach you how to fish:
When you are not sure about how a command works, what options has and what it does, open a terminal and type
man <command>
For example:
man rm
Once in there, you can search for the option. A man page can be really long to read, so in the terminal type:
/<pattern>
So for example, doing:
/-f
You can easily land to:
-f, --force
After typing /-r you'll get:
-r, -R, --recursive
You can move between search results using n (next) and N (previous).
Bonus:
If you need to do something, but you don't know the command name, use apropos to search in man pages:
apropos <pattern>
For example:
apropos directory listing
rm is short for remove. The r flag is to remove directories and their contents recursively and the f means force, and it overrides any confirmation prompts.
Chris
  • 568
As has already been mentioned, rm -rf <ARG> is meant to forcefully remove files recursively, where <ARG> is a directory ( though it can be a file just fine).
The whole point of -r ( recursive removal ) is that rm cannot remove directories if they aren't empty, simply because the underlying system call which rm uses ( unlink ) operates only on empty directories. Thus, what -r flag does, is depth-first search descending into directories and removing files first, and only then when directory is empty - it will remove it. This same effect is achieved via find command with -delete flag (when you don't specify filtering by -type, but that's another story).
As for -f, it does two things - one prevents prompting for whether you want to remove the file or not (such as when you are removing a file owned by another user from within your directory, it won't show rm: remove write-protected regular empty file 'f1'? confirmation prompt), and ignores non-existing files. So for instance, with a non-existent file name, you should get rm: cannot remove 'nonexistent': No such file or directory error.
See also:
Note that in a directory like this
├── AAA
│   └── file2.txt
└── BBB
    └── AAA
        └── file1.txt
running rm -rf AAA will produce
└── BBB
    └── AAA
        └── file1.txt
It's always better check on dummy folders with rm if you re not sure 101%.
