OK, how can i run this:
xrandr --output DVI-D-0 --mode 1920x1080 --rate 144
on startup?
OR:
Make nvidia-settings remember that I've set it to 144Hz and not 60Hz
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 355.06  (buildd@lgw01-22)  Mon Aug  3 21:32:29 UTC 2015
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Philips PHL 272G5"
    HorizSync       30.0 - 160.0
    VertRefresh     50.0 - 146.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce GTX 650"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-1"
    Option         "metamodes" "1920x1080_144 +0+0"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Kim André
  • 1,195
See the post here: wiki.ubuntu - xrandr, this shows you several ways to do it.
Wolfgang
  • 718
You need to start nvidia-settings as root:
sudo nvidia-settings
Go to X Server Display Configuration
change the rate to 144 and click on Save to X Configuration File
Now it should be permanent.
How ever if you want to start your script, when you log on, then you could use ~/xinitrc to run your script.
If you don't want it, then you can use
system Menu > Preferences > Startup Applications
if you copy your script to ~/bin (because ~/bin is included in your $PATH environment), then you can enter the name, otherwise you must enter the full path.
