I am looking for a good drop down terminal that can be split for gnome. At work I use KDE and Yakuake and it works really good but I don't really like KDE that much. I installed Yakuake in gnome and it is really buggy so I removed it and I am looking for a good one.
I also see that there are similar topics but they are all out of date. I have looked into terra but the last update to the ppa was in 2013 so was avoiding that one a bit. I am already using screens so having screens nested inside tmux for multi panel terminal doesn't really sound like it will work that well.
Ubuntu 15.04 with Gnome.
Personally I think Tilda is the best dropdown terminal.
I have tried a lot of them, including Yakuake, and I have to say that Tilda is the most customizable one, at least for my taste. At the github page there is information and screenshots regarding configuration options
Tilda exists in the repositories so you can give it a try fairly easily.
I used terra terminal for this, but unfortunately developement was abandoned a long time ago and installing manually downloaded packages doesn't work (they're installed, but the program fails to start due to some python dependencies).
I ended up using guake in combination with tmux. It's not the same since it doesn't split in two but creates a session similar to screen that you can split, but it's totally depending on keystrokes to create/split and change focus so it's not the same:
Ctrl + B, then % Splits vertically
Ctrl + B, then " Splits horizontally
Ctrl + B, then left/right/up/down Change focus
Ctrl + B + left/right/up/down Change focused window size
Again, I remember reading in some forum that somebody was requesting such a feature in guake itself, but couldn't find any actual code.
Went with terminator and followed this guide to allow for the drop down. Not great, but it works better for my needs than the other solutions.
