I have tried to unblock it using the rfkill command and when I use the rfkill list command it gives this:
~$ sudo rfkill list
[sudo] password for brandon_x_fox:
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: yes
I have tried on the keyboard doing an FN command along with the wifi button and that does not work either. My laptop is a Toshiba Satellite c55-b5200.
All you have to do is
restart your computer, and go to your BIOS settings by pressing esc or delete or another key depending on your motherboard model.
set the BIOS settings to default.
then reboot to Ubuntu and problem solved :D
One other thing to try. Power down the laptop, remove the power cord and battery, then press and hold the power button for 30 seconds. Then connect the battery and power cord and see if the hard block is gone
Source Toshiba Support Forum Solution
Jeremy31
  • 13,293
