I want to know how you would make a script add 1 number each second to a value (Making a spinning loading Gui)
Asked
Active
Viewed 4,479 times
Hoping this does the trick for you:
startTime = os.time()
count = 1
while 1 do
if os.difftime(os.time(), startTime) == 1 then
print (count)
count = count + 1
end
end
Of course in your case, you might not print the value of the counter but instead pass it as a value to your GUI spinner to indicate loading time.
Also, in the 'while' condition, you may want to replace the test condition to something definitive, instead of the 1 (that will result infinitely). Say you're counting till 100, then the test condition would terminate the loop once the counter reaches 100.
Darth Coder
- 342
