21
Ubuntu Core's wiki page page contains the instructions to install Ubuntu Core on a target media:
  1. Uncompress (do not unpack) rootfs
  2. Format target media: at least one partition should be ext2, ext3, or ext4
  3. Unpack Ubuntu Core to ext{2,3,4} partition
  4. Install boot-loader
  5. Install Linux
  6. If the Linux kernel requires modules, add these to /lib/modules/$(uname -r) in the ext{2,3,4} file system
  7. Boot the target device
  8. Install any additional required software using apt-get
But what are the specific commands to do the above? The things I'm specifically confused about are:
  1. Uncompressing and unpacking, what's the difference and how do I do them?
  2. What package should I install if I want the generic kernel provided in regular Ubuntu installation?
  3. I won't be installing any drivers or anything related to kernel other than what's provided in the repos, do I need to worry about manually adding kernel modules?
PS I would like to request that all the commands used in the installation process be mentioned in the answer, for the benefit of ones who're completely unfamiliar and myself, should I ever forget.
Oli
  • 299,380
Oxwivi
  • 18,499
All of those commands will require admin-rights. Easiest is to do sudo su to get a root console.
  1. Archives like your core .tar.gz (this is oneiric, precise beta is here) are combined in one file (packed) and reduced in size (compressed).
    gzip -d ubuntu-core-11.10-core-i386.tar.gz
    will uncompress the core to ubuntu-core-11.10-core-i386.tar (no .gz anymore; one big file).
  2. To partition the device for core it's easiest to use a graphical tool like gparted. When that's not available. See here. In a nutshell - assuming you want to partition the device /dev/sda:
    fdisk /dev/sda then press n p 1 <Return> <Return> a 1 w (for details please see link).
    This creates /dev/sda1 partition.
    mkfs.ext4 /dev/sda1
    This creates an ext4 filesystem on the new partition. You can of course use mkfs.ext3, mkfs.ext2 as well.
    Mount it: mount /dev/sda1 /mnt and go there cd /mnt
  3. tar -xf /path/to/where/you/put/ubuntu-core-11.10-core-i386.tar
    will unpack the core (many files).
  4. grub-install --root-directory=/mnt /dev/sda
    will install the bootloader (this is of course just one of many options).
  5. cp /etc/resolv.conf /mnt/etc/resolv.conf
    will allow network access after chroot-ing (in step 7) by copying the DNS resolver configuration
  6. for f in /sys /proc /dev ; do mount --rbind $f /mnt/$f ; done ; chroot /mnt
    will go to a chroot, see Is there an easier way to chroot than bind-mounting? for details about mount rbind
  7. apt-get update && apt-get install linux-{headers,image}-generic
    will install kernel ("linux")
    Note: it's possible that apt-get update will not work because no network is present.
  8. reboot and you're good to go.
I haven't got a machine to test this so the answer probably won't be complete. I will change my answer should you stumble across problems.
turbo
  • 4,712
You may also check this to install the Ubuntu Core to a USB stick
The Ubuntu Core is providing us a nice startup for playing with Linux. It's saving lots of time for building a rootfs, which might require a lot of efforts to get working.
There could be many ways to play with a rootfs. The simplest could be using chroot to temporarily switch to Ubuntu Core. Most of the utilities you're familiar with should be working. But the network shouldn't be, because there's actually no network configuration. Neither the devfs nor sysfs was created, so many utilities depending on those kernel inode interfaces shouldn't be working.
Yet it's still possible to install packages onto the Ubuntu Core root.
Installation Example
Install the Ubuntu Core rootfs and kernel images.
sudo bash
cd /media/duzy/Root
tar xzvf ~/Downloads/ubuntu-core-15.10-core-amd64.tar.gz
cp -vf /boot/vmlinuz-4.*-generic /media/duzy/Boot
cp -vf /boot/initrd.img-4.*-generic /media/duzy/Boot
useradd --root /media/duzy/Root -s '/bin/bash' -m duzy
passwd --root /media/duzy/Root duzy
Enter new UNIX password: ......
Retype new UNIX password: ......
cp /etc/resolv.conf /media/duzy/Root/resolv.conf
for s in proc sys dev ; do mount --rbind /dev /media/duzy/Root/$s; done
chroot /media/duzy/Root
apt-get update
Install grub (grub-install)
sudo grub-install --boot-directory=/media/duzy/Boot /dev/sdf
sudo grub-mkconfig -o /media/duzy/Boot/grub/grub.cfg
Test USB with KVM (link)
kvm -hdb /dev/sde # NOT the partition (/dev/sde1)!
Or test with VirtualBox
VBoxManage internalcommands createrawvmdk -filename VirtualBox/usbdisk.vmdk -rawdisk /dev/sde
