I tried proposed solutions found here:
How do I install Skype?
How to install Skype 4.3?
and other places, but still no luck. My system was upgraded from Ubuntu 14.04 and Skype worked fine. Once I upgraded, Skype disappeared and I cannot install it. So after attempting a bunch of solutions found on the forum, I am still at the same place so when I enter this:
sudo apt-get install skype skype-bin
I get this
Reading package lists... Done
Building dependency tree
 skype-bin:i386 : Depends: libqtwebkit4:i386 (>= 2.2~2011week36) but it  is not going to be installed
                  Depends: libgl1-mesa-glx:i386 but it is not going to be  installed
If I enter this:
sudo apt-get install libqtwebkit4:i386
I get this
 libqtwebkit4:i386 : Depends: libgl1-mesa-glx:i386 but it is not going to be installed or
                          libgl1:i386
                 Depends: libqt4-opengl:i386 (>= 4:4.5.3) but it is not going to be installed
If I do this, note it is the same as above, but without :i386
I get this:
libqtwebkit4 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Your packages are likely broken.
Proof that your packages are broken
I tested this with two different 64-bit 15.04 installs:
A) fresh 15.04 install (just did it this week) - installing skype works flawlessly with a standard approach of adding the partner repository then apt-get install skype.
B) fresh but overused 15.04 install - this box had a lot of additional software installed (over 15GB). It wasn't upgraded from a previous install like yours. I had exactly the same errors as you. None of the usual fixes out there would work (apt-get -f install / clean / autoclean / whatever - none worked)
This shows that the problem is with your packages. I even tried aptitude to solve the conflicts, but it wanted to uninstall over 500 packages from my system! (no, thanks!).
Possible Solutions
  1. Do a fresh install (15.10 will be available within a few days!)
or
  1. Try to use aptitude to see if it can give you a better solution in your specific case. I'll improve this post with examples upon request.
or
  1. Install all dependencies by hand to get Skype to run on your messed up 15.04 install (its probably not your fault it got messed up - this is likely a bug). I tested this and it works, so that I have Skype on both (A) and (B) above. Two ways you can attempt this:
    1. apt-get install recusivelly all packages above, forcing install when necessary, even though apt-get is complaining. I couldn't get this to work.
    or
    1. (worked for me) Install each library by hand by fetching it from the repository. It is more of a craft to get this right. However, it might be worthwhile since Skype is so central that you might well need it very badly. I will describe this in a couple more edits, but basically involves using ldd, apt-file find, apt-get download package_name:i386, dpkg -x package_name*.deb to decompress, then an ldconfig trick using /etc/ld.so.conf.d. I could just post all libs directly to you, but its 600MB worth of *.so's....
rfabbri
  • 71
First you should remove all skype related software you have had installed before.
Open a terminal and execute :
sudo apt-get purge '^skype.*'
sudo apt-get autoremove
Open Nautilus - press Ctrl + H and delete the .skype folder in /home directory.
Now enable the Canonical partners repository to add it to the software sources.
Open Software & Updates, select Other Software and check Canonical Partners.
Microsoft skype is only available in a 32 bit version - so add the i386 architecture.
sudo dpkg --add-architecture i386
Update the repositories :
sudo apt-get update
Install skype and all dependencies :
cl-netbox
  • 31,491
what you need to do it download Skype from there website.
Open up a Terminal by pressing Ctrl+Alt +T and then type in or copy in
wget http://download.skype.com/linux/skype-ubuntu-precise_4.3.0.37-1_i386.deb
install it by typeing in
sudo dpkg -i skype-ubuntu-precise_4.3.0.37-1_i386.deb
Skype needs has depends on some packages that are not installed we are going to install then by opening up a Terminal and type in
sudo apt-get install -f
after that you should have skype installed and working.
I have tested this on Ubuntu 15.04 32bit and it works.
Neil
  • 4,585
I had similar problems with installation of other packages in Ubuntu before. I tried the following on a clean 15.04 Vagrant box with partner repositories enabled:
    $ apt-cache policy skype skype-bin libqtwebkit4:i386 libgl1-mesa-glx:i386
    skype:
      Installed: (none)
      Candidate: 4.3.0.37-0ubuntu0.12.04.1
      Version table:
         4.3.0.37-0ubuntu0.12.04.1 0
            500 http://archive.canonical.com/ubuntu/ vivid/partner amd64 Packages
    skype-bin:i386:
      Installed: (none)
      Version table:
            500 http://archive.canonical.com/ubuntu/ vivid/partner i386 Packages
    libqtwebkit4:i386:
      Installed: (none)
      Candidate: 2.3.2-0ubuntu7
      Version table:
         2.3.2-0ubuntu7 0
            500 http://archive.ubuntu.com/ubuntu/ vivid/main i386 Packages
    libgl1-mesa-glx:i386:
      Installed: (none)
      Candidate: 10.5.9-2ubuntu1~vivid2
      Version table:
         10.5.9-2ubuntu1~vivid2 0
            500 http://archive.ubuntu.com/ubuntu/ vivid-updates/main i386 Packages
         10.5.2-0ubuntu1 0
After installing skype, I get the following output:
skype:
  Installed: 4.3.0.37-0ubuntu0.12.04.1
  Version table:
 *** 4.3.0.37-0ubuntu0.12.04.1 0
        100 /var/lib/dpkg/status
skype-bin:i386:
  Version table:
libqtwebkit4:i386:
  Installed: 2.3.2-0ubuntu7
  Version table:
 *** 2.3.2-0ubuntu7 0
  Installed: 10.5.9-2ubuntu1~vivid2
  Version table:
 *** 10.5.9-2ubuntu1~vivid2 0
     10.5.2-0ubuntu1 0
As you see, the installed versions match candidates. You need to go over each package from this list that is already installed on your system and make sure it matches the candidate. How?
Let's look at the last package. In order to install the candidate version, run
$ sudo apt-get install -t vivid-updates libgl1-mesa-glx:i386=10.5.9-2ubuntu1~vivid2
libgl1-mesa-glx:i386 is already the newest version.
libgl1-mesa-glx:i386 set to manually installed.
Reasonably, I already had this version installed, but now it's going to be fixed to this version.
You may have some conflicting dependencies that you might have to resolve by removing other packages that depend on non-usual package versions (typically, from strange PPAs):
sudo apt-get purge package
sudo dpkg -r package
sudo dpkg --purge --force-all --dry-run package
Thy those options in the given order and keep in mind that the last command can turn your installation into a trainwreck, so I put --dry-run there, which you have to remove by hand once you're confident about what you're doing.
