I am a novice on openstack. I have followed the steps to intell openstack on my Intel based linux box (not on a virtual machine): http://ubuntu-cloud-installer.readthe...
With "sudo openstack-install --upstream-ppa" after 2 hours, I found all services are up and running, then I was able to login to horizon.
But after reboot the linux and the linux box, I cannot access to horizon any more. Actually, I do not know the proper procedure how to reboot the machine, I just reboot the linux system.
I believe there should a way to shutdown openstack and rejoin the stacks after reboot, which I don't know how. When I checked the "openstack-status", it looks pretty normal and all services are running right after reboot. But I don't really sure they are really running.
notilas
  • 101
If I understand you right, it seems like you have disabled Unity. I did the same in Ubuntu 15.04.
If you can see your mouse, right-click to access the terminal, otherwise hit Ctrl+Alt+t. From there, enter the following in terminal:
dconf reset -f /org/compiz/
then
setsid unity
I found this answer here. Hope it helps.
P.S. To reboot, type sudo reboot or sudo shutdown -r now.
audrow
  • 16
