I'm new to Linux. I need to install Python gtk+ 3. Before that I'm supposed to install and build jhbuild. I installed most of the dependencies manually, since it was throwing errors. I currently get this error when I give the command jhbuild build.
W: Circular dependencies detected: meta-gnome-core -> meta-gnome-core-shell -> dconf -> glib -> gvfs -> glib
W: Circular dependencies detected: meta-gnome-core -> meta-gnome-core-shell -> dconf -> glib -> glib-networking -> glib
W: Circular dependencies detected: meta-gnome-core -> meta-gnome-core-shell -> dconf -> glib -> dconf
W: Circular dependencies detected: meta-gnome-core -> meta-gnome-core-shell -> evolution-data-server -> gtk+ -> adwaita-icon-theme -> gtk+
W: gnome-control-center has a dependency on unknown "network-manager-applet" module
Required packages:
  System installed packages which are too old:
    plymouth (ply-boot-client.pc, required=0.8.9, installed=0.8.8)
    gnutls (gnutls.pc, required=3.1, installed=2.12.23)
    libsystemd-daemon (libsystemd-daemon.pc, required=210, installed=204)
    libsystemd-login (libsystemd-login.pc, required=210, installed=204)
  No matching system package installed:
    libsystemd (libsystemd.pc, required=210)
jhbuild build: Required system dependencies not installed. Install using the command 'jhbuild sysdeps --install' or to ignore system dependencies use command-line option --nodeps
What should I do? Also, if there is a better way to install Python GTK+ 3, then please give suggestions in that regard as well.
I am on Ubuntu 14.04 and behind a college proxy.
As you said
I'm new to Linux
the answer is simple: Forget it.
Trusty is to old to build the latest GNOME/GTK3 release with jhbuild. Therefore upgrade to the latest Ubuntu release. You could compile each version yourself. But trust me, that's the wrong way for you.
You need newer development libraries. In this case, you have to compile it yourself as your are on Trusty.
The library libsystemd-dev isn't available for Trusty. Goto the developer page, download the source code and compile it yourself.
A.B.
  • 92,125
