-2
I install Ubuntu on my laptop.the installation is successful but the problem is.already I install windows 7 at the time OS installation I choose another volume instead of win7 volume so my windows 7 is still present in my system is there any way to get back it
If windows is present, you should be able to select at startup during the grub.
You don't precise which version you are working with so I add this comment :
I noticed with ubuntu 14.04 (maybe 15.04 too), grub may not appear. If grub not appear edit file "/etc/default/grub" and comment "GRUB_HIDDEN_TIMEOUT=0".
You should now have something like this :
GRUB_DEFAULT=0
#GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
Then update grub :
sudo update-grub2
Finally restart your computer and you should be able to select another system.
Inglebard
  • 195
