24
I need to change the default TTL of TCP/IP packets sent from my Ubuntu computer. I found the solution for Windows:
  1. To make reg-file:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\servic es\Tcpip\Parameters]
    "DefaultTTL"=dword:00000081
  2. To execute this commands in console:
    netsh int ipv4 set glob defaultcurhoplimit=129
    netsh int ipv6 set glob defaultcurhoplimit=129
The question is how should I translate this solution for Ubuntu?
Eric Carvalho
  • 55,453
kostiamol
  • 353
To change the default TTL of TCP/IP packets sent from your Linux computer you can run the following command:
sudo sysctl -w net.ipv4.ip_default_ttl=129
Or:
echo 129 | sudo tee /proc/sys/net/ipv4/ip_default_ttl
Or:
sudo bash -c 'echo 129 > /proc/sys/net/ipv4/ip_default_ttl'
But you have to run one of those commands whenever the computer boots. To make this setting persistent across reboots you could append the following line to the file /etc/sysctl.conf:
You should do the same with ipv6 instead of ipv4 if you want to change the settings for ipv6 as well.
Eric Carvalho
  • 55,453
for IPv6:
The other answer here says, "You should do the same with ipv6" but this does not work. IPv6 uses net.ipv6.conf.all.hop_limit and net.ipv6.conf.default.hop_limit. However, these values are overwritten by interface-specific names such as net.ipv6.conf.eth0.hop_limit. To change them all, use:
for N in $(sudo sysctl --all 2>/dev/null |grep -Eo "^net\.ipv6\.conf\.[^\.]+\.hop_limit"); do
    sudo sysctl --write "$N=128"
done
where 128 is the desired new value.
To make this permanent (survive reboot) for IPv4 and IPv6:
sudo sysctl --all 2>/dev/null |grep -E -e "^net\.ipv6\.conf\.[^\.]+\.hop_limit" -e "net.ipv4.ip_default_ttl" |sudo tee /etc/sysctl.d/11-custom-ttl-hop.conf
bitinerant
  • 1,157
