I need to list files and dirs with names starting with jre (small and capital letters are allowed).
When I execute:
ls | grep jre
...it greps just low capital letters and gives output with jre not only in start position. Actually I have feeling that grep is not a good choice at all in this case.
How to solve my problem?
vico
  • 4,717
  • 23
  • 66
  • 89
you can use find. In your case you can run
find -maxdepth 1 -iname 'jre*'
Explanation:
find searches for files/directories with the given parameters: -maxdepth 1 restricts the search to the current directory. Otherwise, it would search in all subdirectories too. -iname takes the pattern and searches case insensitive. The pattern itself 'jre*' means the string should begin with "jre" and the continue with a arbitrary number of cahracters.
Alternatively, if you want to use grep:
ls | grep -i '^jre'
-i toggles case-insensitive search and the ^ results in finding only matches with "jre" at the beginning
Wayne_Yux
  • 4,942
Find should do the trick:
find . -iname 'jre*'
Jakob Lenfers
  • 1,105
  • 17
