I've just installed Ubuntu 15.04 with the guest additions (on VirtualBox 5.0.2, video mem=128MB, 3d enabled). Graphics are very "sluggish" even with HiDPI (Retina) disabled.
After disabling all animations I could find I still can't use the Dash. It takes ~3 seconds to fade in and another ~3 to go away again.
I've also replaced the guest additions with sudo apt-get install virtualbox-guest-dkms virtualbox-guest-x11 (no change).
This and this answer did not help.
$ /usr/lib/nux/unity_support_test -p
pci id for fd 4: 80ee:beef, driver (null)
libGL error: core dri or dri2 extension not found
libGL error: failed to load driver: vboxvideo
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.6, 256 bits)
OpenGL version string: 3.0 Mesa 10.5.2
Not software rendered: no
Not blacklisted: yes
GLX fbconfig: yes
GLX texture from pixmap: yes
GL npot or rect textures: yes
GL vertex program: yes
GL fragment program: yes
GL vertex buffer object: yes
GL framebuffer object: yes
GL version is 1.4+: yes
Unity 3D supported: no
$ modprobe -c|grep vboxvideo
alias pci:v000080EEd0000BEEFsv*sd*bc*sc*i* vboxvideo
I also get a message about "vboxvideo: module verification failed":
$ cat /var/log/syslog|grep vbox
Aug 30 23:14:09 udev vboxadd[8667]: Starting the VirtualBox Guest Additions ...done.
Aug 30 23:14:10 udev vboxadd-service[8754]: Starting VirtualBox Guest Addition service ...done.
Aug 30 23:14:10 udev systemd[1]: vboxadd-service.service: control process exited, code=exited status=1
Aug 30 23:14:10 udev systemd[1]: Unit vboxadd-service.service entered failed state.
Aug 30 23:14:10 udev systemd[1]: vboxadd-service.service failed.
Aug 30 23:14:42 udev kernel: [14302.735185] vboxvideo: module verification failed: signature and/or required key missing - tainting kernel
Aug 30 23:14:42 udev kernel: [14302.736192] [drm] Initialized vboxvideo 1.0.0 20090303 for 0000:00:02.0 on minor 0
Aug 30 23:14:42 udev kernel: [14302.942282] vboxguest: misc device minor 56, IRQ 20, I/O port d020, MMIO at 00000000f0400000 (size 0x400000)
Aug 30 23:14:42 udev kernel: [14302.942283] vboxguest: Successfully loaded version 5.0.2 (interface 0x00010004)
Aug 30 23:14:42 udev kernel: [14306.524633] vboxsf: Successfully loaded version 5.0.2 (interface 0x00010004)
Aug 30 23:14:42 udev systemd-modules-load[188]: Inserted module 'vboxvideo'
Aug 30 23:14:43 udev vboxadd[634]: Starting the VirtualBox Guest Additions ...done.
Aug 30 23:14:43 udev vboxadd-service[896]: Starting VirtualBox Guest Addition service ...done.
Aug 30 23:14:43 udev systemd[1]: vboxadd-service.service: control process exited, code=exited status=1
Aug 30 23:14:43 udev systemd[1]: Unit vboxadd-service.service entered failed state.
Aug 30 23:14:43 udev systemd[1]: vboxadd-service.service failed.
I'd guess this is a bug (I reported it here) but is there a workaround? Can I force vboxvideo to load?
