Several projects that I am trying to build from scratch appear to need msgfmt in order to build. They all fail.
However, when I try to run it directly on the command line I get:
$ msgfmt
msgfmt: error while loading shared libraries: libgettextsrc-0.18.1.so: cannot open shared object file: No such file or directory
I have gettext installed, but it seems to be 0.18.3 instead of 0.18.1:
ii gettext 0.18.3.1-1ubuntu3 amd64 GNU Internationalization utilities ii gettext-base 0.18.3.1-1ubuntu3
Ubuntu version is:
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04.3 LTS
Release: 14.04
Codename: trusty
Edit:
$ apt-cache policy gettext
gettext:
   Installed: 0.18.3.1-1ubuntu3
   Candidate: 0.18.3.1-1ubuntu3
   Version table:
    *** 0.18.3.1-1ubuntu3 0
   500 http://us-east-1.ec2.archive.ubuntu.com/ubuntu/ trusty-updates/main amd64 Packages
   100 /var/lib/dpkg/status
   0.18.3.1-1ubuntu2 0
   500 http://us-east-1.ec2.archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
And then
$ ls -la $(which msgfmt)
-rwxr-xr-x 1 root root 79104 Jul 13 09:14 /opt/bitnami/common/bin/msgfmt
A.B.
  • 92,125
Peter K.
  • 145
You have the right gettext package installed, but your PATH is a bit inconvenient and therefore you use the "wrong" msgfmt.
The path /opt/bitnami/common/bin should be after /usr/bin and so on. Place /opt/bitnami/common/bin at the end of your PATH settings.
A.B.
  • 92,125
