I installed LXDE in my Ubuntu 14.04. Now I am unable to remove it from login screen though I used PURGE and all same sort of commands. Now when I try to remove it terminal says
Reading package lists... Done
Building dependency tree
Package 'lxde' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 18 not upgraded.
And still i am getting option for LXDE at login
Thanks
Ravan
  • 9,567
Open a terminal and change directory to /usr/share/xsessions. In there, use sudo rm to remove options you don't want to see in your login screen. Then log out and log back in again.
DK Bose
  • 44,553
If you still have the LXDE option at login, run the following two commands in your terminal
cd /usr/share/xsessions
Then
sudo rm LXDE.desktop openbox.desktop
