-1
I tried to use this command: sudo apt-get install libboost-regex1.55-dev:i386
And i have some errors:
Reading package lists... Done
Building dependency tree
 libboost-regex1.55-dev:i386 : Depends: libboost1.55-dev:i386 (= 1.55.0+dfsg-3ubuntu2) but it is not going to be installed
dobey
  • 41,650
open the terminal then type:
sudo dpkg --add-architecture i386
enter your password then type:
sudo apt-get update
enter your password.
