I'm running Ubuntu 14.04 64 bit on my Laptop. I'm trying to install dolphin emulator on my system Here is the terminal output.
Selecting previously unselected package dolphin-emu.
(Reading database ... 205709 files and directories currently installed.)
Preparing to unpack /home/tbh/Downloads/de.deb ...
Unpacking dolphin-emu (4.0) ...
dpkg: dependency problems prevent configuration of dolphin-emu:
 dolphin-emu depends on libavcodec53 (>= 6:0.8.3-1~) | libavcodec-extra-53 (>= 6:0.8.6); however:
Package libavcodec53 is not installed.
Package libavcodec-extra-53 is not installed.
dolphin-emu depends on libavformat53 (>= 6:0.8.3-1~) | libavformat-extra-53 (>= 6:0.8.6); however:
Package libavformat53 is not installed.
Package libavformat-extra-53 is not installed.
dolphin-emu depends on libavutil51 (>= 6:0.8.3-1~) | libavutil-extra-51 (>= 6:0.8.6); however:
Package libavutil51 is not installed.
Package libavutil-extra-51 is not installed.
dolphin-emu depends on libglew1.8 (>= 1.8.0); however:
Package libglew1.8 is not installed.
dpkg: error processing package dolphin-emu (--install):
dependency problems - leaving unconfigured
Processing triggers for bamfdaemon (0.5.1+14.04.20140409-    0ubuntu1+elementary2~ubuntu14.04.1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for gnome-menus (3.10.1-0ubuntu2) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
Processing triggers for mime-support (3.54ubuntu1.1) ...
dolphin-emu
Have you tried updating your system by doing sudo apt-get update? If you haven't, I'd highly recommend doing that before proceeding to install the .deb file.
From the looks of it, you are missing some files. Hopefully doing sudo apt-get update works for you. If not, I'd highly recommend proceeding to do the following below. This option is a fail proof option of getting Dolphin installed.
sudo add-apt-repository ppa:dolphin-emu/gcc-for-dolphin
sudo add-apt-repository ppa:dolphin-emu/ppa
sudo apt-get update
sudo apt-get install dolphin-emu
The following repository sudo add-apt-repository ppa:dolphin-emu/gcc-for-dolphin needs libstdc++6 (>=4.9) in order to be run dolphin-emu on 12.04 and 14.04.
Nickolaus L.
  • 146
