Hi i have annoying problem with steam in ubuntu. After running steam it showed me that error:
    Steam needs to install these additional packages:
    libgl1-mesa-dri:i386, libgl1-mesa-glx:i386, libc6:i386
..........................................................W: Failed to fetch cdrom://Ubuntu 14.04.3 LTS _Trusty Tahr_ - Beta amd64 (20150805)/dists/trusty/main/binary-i386/Packages  Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
W: Failed to fetch cdrom://Ubuntu 14.04.3 LTS _Trusty Tahr_ - Beta amd64 (20150805)/dists/trusty/restricted/binary-i386/Packages  Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
E: Some index files failed to download. They have been ignored, or old ones used instead.
Reading package lists... Done
Building dependency tree
 libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 10.1.3-0ubuntu0.4)
 unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
                        Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
N: Ignoring file 'steam.list.disable' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Press return to continue:
And I want to add that i am new to linux(i spend like 14 years with Windows and few days ago i changed it to Ubuntu) so i dont know everything perfectly.
frast
Your update settings have your CD-ROM files enabled. So every time it tries and updates it automatically looks for those files, which by definition are outdated. Just unselect the cdrom option and:
sudo apt-get update && sudo apt-get upgrade
should run normally without CD-ROM install files selected.
Fabby
  • 35,017
In 14.04.3 this worked for me perfectly.
sudo apt-get install steam -y
Goddard
  • 4,860
