Apparently spotify needs libavcodec54 (or 53 or 52) to play local mp3 files. Unfortunately - it doesn't work with libavcodec56 which is in Vivid.
I tried symlinking libavcodec56 under name of *54, but it didn't work.
I also tried to compile from trusty sources, but it was failing too.
Is there any place or procedure that I could use to get working libavcodec54 for vivid?
pl_rock
  • 11,715
  1. Download the neccessary deb files
    cd
    wget http://mirrors.kernel.org/ubuntu/pool/universe/o/openjpeg/libopenjpeg2_1.3+dfsg-4.7ubuntu1_amd64.deb
    wget http://mirrors.kernel.org/ubuntu/pool/universe/liba/libav/libavcodec54_9.18-0ubuntu0.14.04.1_amd64.deb
    wget http://mirrors.kernel.org/ubuntu/pool/universe/liba/libav/libavutil52_9.18-0ubuntu0.14.04.1_amd64.deb
  2. Install, in the order below
    sudo dpkg -i libopenjpeg2_1.3+dfsg-4.7ubuntu1_amd64.deb
    sudo dpkg -i libavutil52_9.18-0ubuntu0.14.04.1_amd64.deb
    sudo dpkg -i libavcodec54_9.18-0ubuntu0.14.04.1_amd64.deb
Tested in my Vivid system
% lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 15.04
Release:    15.04
Codename:   vivid
% apt-cache policy libopenjpeg2
libopenjpeg2:
  Installed: 1.3+dfsg-4.7ubuntu1
  Candidate: 1.3+dfsg-4.7ubuntu1
  Version table:
 *** 1.3+dfsg-4.7ubuntu1 0
        100 /var/lib/dpkg/status
% apt-cache policy libavutil52
libavutil52:
  Installed: 6:9.18-0ubuntu0.14.04.1
  Candidate: 6:9.18-0ubuntu0.14.04.1
  Version table:
 *** 6:9.18-0ubuntu0.14.04.1 0
% apt-cache policy libavcodec54
libavcodec54:
  Version table:
A.B.
  • 92,125
You can almost certainly just download the .deb file from the earlier version of Ubuntu and install it in parallel with the new one.
I've had to install older libraries in parallel with newer ones a few times for situations like this.
Try installing the deb from here:- http://packages.ubuntu.com/trusty-updates/amd64/libavcodec54/download
You may also need to install some other older libraries as dependencies tho.
