I realize that there are many questions around here to answer that problem - but none seems to work for me so far.
I attempted:
sudo update-rc.d mysql defaults
This resulted in a locale error, which I fixed with How do I fix my locale issue? by altering /etc/environment
LC_ALL=en_US.UTF-8
LANG=en_US.UTF-8
Now, by trying update-rc.d again, I get:
update-rc.d: warning: /etc/init.d/mysql missing LSB information
update-rc.d: see <http://wiki.debian.org/LSBInitScripts>
System start/stop links for /etc/init.d/mysql already exist.
I found a suggestion on http://ubuntuforums.org/showthread.php?t=1313898 to use:
user@computer:/etc/init.d$ sudo update-rc.d -f mystartupscript remove
user@computer:/etc/init.d$ sudo update-rc.d mystartupscript defaults
user@computer:/etc/init.d$ sudo chmod +x ./mystartupscript
But do I risk to break my mysql implementation here? It's on a production server, so I can't just try it out and then suddenly be unable to start up mysql again.
In the end, the mysql server needs to run on startup. We had a few server restarts coming from the host, and everytime when that's the case, the database is not started and the hosted pages remain down until mysql is started manually.
Edit: /etc/init.d/mysql contents
#!/bin/sh -e
# upstart-job
# Symlink target for initscripts that have been converted to Upstart.
set -e
INITSCRIPT="$(basename "$0")"
JOB="${INITSCRIPT%.sh}"
if [ "$JOB" = "upstart-job" ]; then
if [ -z "$1" ]; then
echo "Usage: upstart-job JOB COMMAND" 1>&2
exit 1
fi
JOB="$1"
INITSCRIPT="$1"
shift
else
echo "Usage: $0 COMMAND" 1>&2
exit 1
fi
fi
COMMAND="$1"
shift
if [ -z "$DPKG_MAINTSCRIPT_PACKAGE" ]; then
ECHO=echo
else
ECHO=:
fi
$ECHO "Rather than invoking init scripts through /etc/init.d, use the service(8)"
$ECHO "utility, e.g. service $INITSCRIPT $COMMAND"
# Only check if jobs are disabled if the currently _running_ version of
# Upstart (which may be older than the latest _installed_ version)
# supports such a query.
# This check is necessary to handle the scenario when upgrading from a
# release without the 'show-config' command (introduced in
# Upstart for Ubuntu version 0.9.7) since without this check, all
# installed packages with associated Upstart jobs would be considered
# disabled.
# Once Upstart can maintain state on re-exec, this change can be
# dropped (since the currently running version of Upstart will always
# match the latest installed version).
UPSTART_VERSION_RUNNING=$(initctl version|awk '{print $3}'|tr -d ')')
if dpkg --compare-versions "$UPSTART_VERSION_RUNNING" ge 0.9.7
then
initctl show-config -e "$JOB"|grep -q '^ start on' || DISABLED=1
fi
case $COMMAND in
status)
$ECHO
$ECHO "Since the script you are attempting to invoke has been converted to an"
$ECHO "Upstart job, you may also use the $COMMAND(8) utility, e.g. $COMMAND $JOB"
$COMMAND "$JOB"
start|stop)
$ECHO
if status "$JOB" 2>/dev/null | grep -q ' start/'; then
RUNNING=1
fi
if [ -z "$RUNNING" ] && [ "$COMMAND" = "stop" ]; then
exit 0
elif [ -n "$RUNNING" ] && [ "$COMMAND" = "start" ]; then
exit 0
elif [ -n "$DISABLED" ] && [ "$COMMAND" = "start" ]; then
exit 0
fi
$COMMAND "$JOB"
restart)
$ECHO
$ECHO "Upstart job, you may also use the stop(8) and then start(8) utilities,"
$ECHO "e.g. stop $JOB ; start $JOB. The restart(8) utility is also available."
RUNNING=1
fi
if [ -n "$RUNNING" ] ; then
stop "$JOB"
fi
# If the job is disabled and is not currently running, the job is
# not restarted. However, if the job is disabled but has been forced into the
# running state, we *do* stop and restart it since this is expected behaviour
# for the admin who forced the start.
if [ -n "$DISABLED" ] && [ -z "$RUNNING" ]; then
exit 0
fi
start "$JOB"
reload|force-reload)
$ECHO
$ECHO "Upstart job, you may also use the reload(8) utility, e.g. reload $JOB"
reload "$JOB"
$ECHO
$ECHO "The script you are attempting to invoke has been converted to an Upstart" 1>&2
$ECHO "job, but $COMMAND is not supported for Upstart jobs." 1>&2
exit 1
esac
