I want to execute a script that requires root privileges without entering a password. There are similar questions/answers but non seems to work for me.
I placed my script in /home/kf/bin (I added the bin dir myself) and included this directory in my path so I can run it from everywhere.
The script: trim.sh:
#! /bin/sh
sudo fstrim -v /
I changed the ownership of the script to root:
 sudo chown root:root /home/kf/bin/trim.sh
and made it executable
sudo chmod 700 /home/kf/bin/trim.sh
next I added a line to my sudoers file with visudo:
kf   ALL=(ALL) NOPASSWD: /home/kf/bin/trim.sh
When I login again and execute the script with trim I still need to enter my password. I know I can make a cron for this but I also want to be able to execute the script manually without entering my password. Any help appreciated.
edit:
My sudoers file looks like this:
Defaults        env_reset
Defaults        mail_badpass
Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin: /usr/bin:/sbin:/bin"
root    ALL=(ALL:ALL) ALL
%admin ALL=(ALL) ALL
%sudo   ALL=(ALL:ALL) ALL
chaos
  • 28,186
Change the line in the sudoers file to:
kf   ALL=(ALL) NOPASSWD: /sbin/fstrim
I don't recommend, adding the script in /etc/sudoers, because the script can be altered and every command (the whole script) would then be executed with root privileges.
chaos
  • 28,186
What you're looking for is the setuid bit, it allows the users to exec a program with the permissions of its owner.
/!\ Be careful with it, it's often a bad solution, due to the security problems it exposes.
