I tried the fork bomb code :
and closed the PuTTy. Now it is not accepting the new connections(Denial of Service attack).
How can I recover from that ?
heemayl
  • 93,925
Paresh
  • 43
You might need to hard reboot the computer.
Assuming you have console access, you might try to get the process group ID (PGID) and kill that with :
kill -- -PGID
Or use SIGKILL instead of SIGTERM :
kill -9 -- -PGID
but it might not be possible to get the PGID practically as the system might be already occupied by the forked processes creating a deadlock.
This deadlock can happen when you don't have a sufficient limit on the number of processes a user or group can own, so it's better to set a lower limit before trying something destructive like a fork-bomb.
Fabby
  • 35,017
heemayl
  • 93,925
You have used the classic "fork bomb" to use up all of your system's processes, and now your cannot get the system to run a process to help you (and all commands, programs, etc. require a process to run "in"). Any intervention will have to come from outside the system (e.g.,reset the VM, cycle the power, CtrlAltDelete). Did you not understand what then code says?
Define a shell function, called ":".
Begin the definition of the function, which is:
Call the ":" function.
Pipe the output of ":"
to another call to ":"
Fork a process to put the pipeline (:|:) in the background.
End of definition of the function ":"
End of the shell statement defining the ":" function
Call the ":" function to begin.
If you run code without understanding it, you accept the results of the code.
waltinator
  • 37,856
According to this it should in theory be possible to use Alt+SysRq+f to get rid of fork bombs — although, again, probably only possible if the kernel is capable of allocating enough memory to kill it.
If you can't connect again, you do not have a chance. Maybe you can wait for an out of memory error
If you can connect, try the command below
pkill -f :
And as you said in your comments
I am running it in Virtual box
Reset the machine via VirtualBox.
Fabby
  • 35,017
A.B.
  • 92,125
