15
Recently I've installed Ubuntu 15.04, everything had worked fine, but suddenly language change stopped working. I don't know what could be the cause of this, because I didn't notice it right away. Now, I've tried to assign different shortcuts to language change, I've tried to use language icon in the top right corner and simple reboot of course. Nothing seems to work. Could you please tell me what could be wrong and what can I do with it?
UPD: forgot to mention that in the top menu my second language(Russian) is present and I even can choose it, but when I type it's still English. UPD2: I've tried to add another language and even change order of input sources, but it didn't work out either. My input language is always English.
1.I recommended you to read this Ubuntu documentation about "use alternative input source" .
It is explaining it step by step .
2.you can try reconfigure the keyboard configuration with this command
dpkg-reconfigure keyboard-configuration
I hope it helps you.
Farimah
  • 328
My problem was that the shortcut for change kept setting to "Shift L" or such. I couldn't get rid of the <Mod2>.
After trying dconf, gsettings, gconftool, gconftool-2 and other, I found out in other question that I have to turn off NumLock and set the shortcut again.
See https://bugs.launchpad.net/ubuntu/+source/unity/+bug/981628
Amir Uval
  • 1,161
I have this exact problem with Ubuntu 20.04.1 LTS.
I don't know how to solve it and solutions above didn't work for me.
Still, there is a workaround: you can try adding another non-latin input source in "Region & Language" setting menu - I usually pick Albanian b/c it is easiest to add. Once I add it, switching to another input source starts working again and then newly added input source can be removed again - until this bug resurrects itself.
For what it is worth - I use standard keyboard that worked fine with the other linux distribution I had before switching to Ubuntu (Debian) and I didn't configure system in a non-trivial manner - the setup was fairly standard.
Alex
  • 101
It happened to me after updating from Ubuntu (+budgie) 20.10 to 21.04. I had Arabic and English but only English worked after the upgrade. The fix was to remove Arabic from the input source then add it again.
