I have Lenovo Thinkpad Edge E430(32-bit) laptop. I have installed the 14.04 ubuntu version fresh rather than upgrading from the previous version. I am using this version for around 1 year. The wifi disconnection problem i am encountering from starting(after installing 14.04) itself. The wlan0 info is:
wlan0 IEEE 802.11bgn ESSID:"naruto"
      Mode:Managed  Frequency:2.437 GHz  Access Point: A0:21:B7:8B:A5:70
      Bit Rate=72.2 Mb/s   Tx-Power=20 dBm
      Retry  long limit:7   RTS thr=2347 B   Fragment thr:off
      Power Management:off
      Link Quality=70/70  Signal level=-22 dBm
      Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
      Tx excessive retries:0  Invalid misc:48   Missed beacon:0
Network Device Info is given below:
description: Wireless interface
   product: RTL8191SEvB Wireless LAN Controller
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:03:00.0
   logical name: wlan0
   version: 10
   serial: f0:7b:cb:9f:11:09
   width: 32 bits
   clock: 33MHz
   capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
   configuration: broadcast=yes driver=rtl8192se driverversion=3.13.0-62-generic firmware=N/A ip=10.0.0.2 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
   resources: irq:17 ioport:2000(size=256) memory:f0500000-f0503fff
Problems: 1) When the system remain connected for ling time to wifi network around more than half an hour/sometimes hour, the wifi signal gets automatically disconnected(No weak signal issue as the wifi router is hardly 1m away and max 2 systems are connected to the router). After disconnection , the system is unable to connect to any wifi signal. The only solution is restart the system.
This problem is occurring very frequently.
2) Whenever i wake up the system from suspend state, the system doesnot able to connect to wifi network. The only solution is restart the system. This issue is always.
NOTE: Above both problems , after restarting the system, the system again connect the wifi signal successfully. But after long use it again disconnected. What to do?
Sanjeev
  • 225
First of all I suggest upgrading kernel by running
sudo apt-get install linux-generic-lts-vivid
If the problem persists after reboot, install a driver this way
sudo add-apt-repository ppa:hanipouspilot/rtlwifi
sudo apt-get update
sudo apt-get install rtlwifi-new-dkms linux-firmware
Pilot6
  • 92,041
I had the same problem. This worked for me.
I am using dual boot with Windows 10 I got a USB wifi adaptor and installed the drivers using Windows and connected to the internet with the USB adaptor. Then uninstalled the drivers and restart Windows,this will reset original drivers. That solved the problem. If you do not have dual boot then im not sure what you could do.
Stan
