I just downloaded a Plugin for the Claws E-mail program:
sudo apt-get install claws-mail-vcalendar-plugin
And according to the instructions, all you need to do is to open it
USAGE
   Before using a plugin you must instruct Claws Mail to load it on
   startup.
   For this you must go “Configuration” menu on main window toolbar, open
   “Plugins...”  dialog, click on the “Load plugin...”  button and select
   the plugin file, named vcalendar.so, and press the “Open” button.
...But I cannot find vcalender.so in my home directory.
Any hints where I should look for it?
impalle
  • 177
Maybe I misunderstood you, because the instructions seem quite straightforward.
In Claws Mail just click on Configuration -> Plugins... -> Load... and it should direct you right to the plugin directory where you find the vcalender.so
( this should be something like /usr/lib/x86_64-linux-gnu/claws-mail/plugins )
Ron
  • 20,938
