I'm trying to install Ubuntu in my Dell Vostro 3546, which already has Windows 8 on it. I have a 320GB HDD with 2GB RAM.
I am using a bootable USB drive to this. All goes well for the first part. I choose my language, connect to WiFi and select the option to install third party software and updates. Then there is the option about whether to install Ubuntu alongside Windows 8 or something else.
Whenever I choose the "install alongside" option and press continue, the installation exits to a black screen showing the following text:
wait-for-state stop/waiting
* Stopping rsync daemon rsync
* speech-dispatcher disabled; edit /etc/default/speech-dispatcher
* Asking all remaining processes to terminate ...
How should I proceed?
Fabby
  • 35,017
In my installation of Ubuntu 12.10 alongside Win 8, I ended up having to create the partitions for Ubuntu from the Windows side using 'Disk Management'. If your 320GB HD is all utilized for Windows you will need to do this as well. Set up at least 2 partitions, one for / and a swap partition, formatting as FAT32. Now when you begin the Ubuntu install, there are now empty partitions that can be chosen as the drive to install Ubuntu into (/)and the swap partition. Ubuntu will look for drives and after found you can simply answer questions to tell where install takes place and filesystem to set up (I used ext4). Hope this helps Craig
Craig
  • 127
-1
I have experienced same problem, while I was trying to install Ubuntu 14.0 alongside with Windows 7
Tried to leave unallocated or free space next to the C: drive, further proceeded with the Ubuntu installation as dual boot. It now worked fine.
Jens Erat
  • 5,131
  • 33
  • 37
