I like many other have this question and can't believe no one has found a way around this.
I have a usb drive that is a UDF format and can not format it was given to me by my company and said i may do with it what i want after i installed the software on my pc.
I have read all the forums possible and cannot find a answer.
I have tried everything I could find on the net... Only going to paste a few stuff so you guys can have one more go at this.
Device info
[ 4328.431126] usb 1-8: Manufacturer: SMI Corporation
[ 4328.431417] usb 1-8: ep 0x81 - rounding interval to 128 microframes, ep desc says 255 microframes
[ 4328.431427] usb 1-8: ep 0x2 - rounding interval to 128 microframes, ep desc says 255 microframes
[ 4328.432091] usb-storage 1-8:1.0: USB Mass Storage device detected
[ 4328.432520] scsi host7: usb-storage 1-8:1.0
[ 4329.703063] scsi 7:0:0:0: CD-ROM            SMI      USB DISK         1100 PQ: 0 ANSI: 2
[ 4329.704295] sr 7:0:0:0: [sr1] scsi3-mmc drive: 0x/0x caddy
[ 4329.704616] sr 7:0:0:0: Attached scsi CD-ROM sr1
[ 4329.704777] sr 7:0:0:0: Attached scsi generic sg2 type 5
[ 4329.898756] UDF-fs: INFO Mounting volume 'company app', timestamp 2015/04/02 11:22 (1078)
> root@TriGz:/home/trigz# hdparm -r0 /dev/sr1
/dev/sr1:
 setting readonly to 0 (off)
 readonly      =  0 (off)
root@TriGz:/home/trigz# mkdosfs -F 32 -I /dev/sr1
mkfs.fat 3.0.27 (2014-11-12)
mkdosfs: unable to open /dev/sr1: Read-only file system
root@TriGz:/home/trigz# mkfs -t vfat /dev/sr1
mkfs.vfat: unable to open /dev/sr1: Read-only file system
root@TriGz:/home/trigz# mkudffs --media-type=hd --blocksize=512 /dev/sr1
Error opening device: Read-only file system
Would be really nice if someone has a way around this issue!
TheWanderer
  • 19,525
  • 52
  • 65
TriGz
Think about it for a minute. When the system has a device mounted (UDF-fs: INFO Mounting volume 'company app', timestamp 2015/04/02 11:22 (1078)). the (in this case) UDF filesystem code reads file indexes, brings the structure of the device into memory, and gets ready to mediate requests for the data. Now, if you format the device, the in-memory copy of UDF metadata is trashed on the "disk" but "valid" in memory. Bad scene!
The simple answer is to umount the USB key first.
waltinator
  • 37,856
