142
It's driving me nuts! I just want to transfer one simple file from laptop to server.
I'm using ubuntu on both machines.
So I have:
-rwxr-xr-x 1 sandro    414622 2011-10-14 23:42 sandrophoto-html.tar.gz
And I'm sending it using:
sudo scp -P XXXX sandrophoto-html.tar.gz usern@server.local:/media/xx/xx/xx
And I get: scp: /media/xx/xx/xx/sandrophoto-html.tar.gz: Permission denied
p.s. I might be doing this other way around - I want to send file tar.gz that is located on my desktop, to remote server into the folder /media/yadayda
Edd
  • 103
8 Answers8
136
You have things in the right order from what I understand, the general way an scp is done is:
scp sourceuser@sourcehost:/path/to/source/file destinationuser@destinationhost:/path/to/destination/
Judging by your question, you have a local file you want to send to the destination server. So you have the right syntax which is good!
If you're getting permission denied, then you're not using the correct username or something's amiss with the authentication. Most likely, it's because the sudo command only works locally, for starters, so it won't give you root on the remote box, so that's probably the problem. Make sure that the user you are logging in as on the remote server has write permissions to the location you're trying to write to.
If the problem is the destinationuser doesn't have access to that location without sudo, move the file to the destinationuser's home folder then sudo mv the file from the shell on the other server to put it in the right location.
Anna
  • 2,190
74
Hi had this same permission error problem solved it this way
Make sure the directory you are copying to on 192.168.0.4 is owned by the user username
chown username downloads
On your local machine then do
sudo scp filename.zip username@192.168.0.4:/etc/Myfiles/downloads
Cheers
Bruno Pereira
  • 74,715
37
Permisssion Denied means you are not the root of the server. You just hold an account there. So in that case you need to do this:
sudo scp -r /path2yourFolder/ username@server_Ip:/home/username
This will copy to your home directory on server.
This will also work:
scp -r /path2yourFolder/ username@server_Ip:~/
Eric Carvalho
  • 55,453
16
I had a similar problem, it happened because ssh takes -p xxxx for specifying the port while scp takes -P xxxx to specify the port. Minor inconsistency, so easy to miss :(
Dirk
  • 261
12
This error occurred for me when the file already existed in the target location and the existing file had read-only permissions (preventing the file from being overwritten). In my case, I just logged in and deleted the existing file and that corrected the problem.
Kevin
  • 121
Had the same problem. I found out that the directory containing my source file did not have enough permission. So I just changed the mode recursively using:chmod -R 771 directory_path on the source machine.
Changba
I was trying to copy from my local machine as username@localhost; the SSH key I was using wasn't registered to access my localhost, so I was getting permission denied. When I removed that from the source portion, it worked.
Chaim Eliyah
  • 1,169
If there is an identically named file owned by root on the remote host (target) the transfer will fail. This assumes you are running scp as an ordinary user on both hosts, i.e. your remote host user is not root.
mr.zog
  • 216
