I used an app in Windows 7, I think called dimmer to make the screen change its contrast settings so I could dim it lower than the controls of the PC defaults such as function key or the power options in control panel.
Are there any of these type apps for Ubuntu 15.04 or approved for the latest Ubuntu LTS version on a PC-laptop.
My computer has the use of function keys that change its brightness. It uses a 0-8 step brightness scale where 0 is the least bright and 8 is the brightest. 0 is too bright for my comfort level especially at night
Following the suggestion in an answer below I added the following to etc/default/grub:
GRUB_CMDLINE_LINUX="resume=UUID=8bcb4169-f5ab-4ab6-b644-23e528088d41 acpi_backlight=vendor"
and updated grub
My screen brightness did not go any dimmer than it had before. Oddly the brightness level seems to go to level 2 brightness on a 0-8 scale every time I reboot which it did not do prior to the etc/default/grub change. I reverted my grub file back to previous settings.
I've installed Indicator-Brightness but this app does not dim my desktop any further than my function keys do and there are no menus to configure it to do so.
I actively pursued other related questions to find a solution and reporting results of that action here. Its a process that takes time. To those that have provided input, Thank you for being patient.
There are many aspects to graphics, screen brightness, contrasts, color temp, gamma.
I tried
xbacklight -set 50
xbacklight -dec 10 and 03 etc.
This never increased or decreased beyond the usual 0-8 steps the PC provides i.e. no difference than current function key levels.
Interestingly a comment below my question by Serg Kolo (thanks :) led me to info on xrandr via the linked sources at the bottom of the information he provided concerning his script:
xrandr -q | grep " connected"
xrandr --output LVDS1 --brightness 0.5
I had no idea this was available and already installed - apparently. With the second command in terminal my screen went darker than it ever has. I then tested:
xrandr --output LVDS1 --brightness 0.9
Which got me back to the usual lowest level. This appears to be changing contrast levels not brightness, which is exactly what I was asking about. A simple command in terminal is as good as an App.
I have since studied xrandr so that I can get an idea of how that command works.
Perhaps someone could explain xrandr in easy terms but until then please explore the information from the link above.
Edit Sept 16
In good faith and collaboration I decided to try the script from Serg's answer below. Following his directions I was able to make this script work for me. I wish I knew how the script determines what the name of my screen is for the use of xrandr command but the good news is it works.
Thank you Serg and all for your input
xtrchessreal
  • 1,081
  • 15
  • 31
Follow these steps exactly:
  1. Open terminal via Ctrl-Alt-T
  2. Create a folder for the script
    mkdir -p ~/bin
  3. Open the file ~/bin/setup.sh in gedit.
    gedit ~/bin/setup.sh
  4. Copy over the code below save the file, close the editor.
    #!/bin/sh
    # Author: Serg Kolo
    # Date: Mon Aug 24 , 2015
    # Description: setup script for creating
    # launcher and setting up the Dimmer script
    DESKFILE="$HOME/bin/Dimmer.desktop"
    SCHEMA="com.canonical.Unity.Launcher"
    KEY="favorites"
    SCRIPTFILE="$HOME/bin/Dimmer.sh"
    createBinFolder() {
     if [ ! -e "$HOME/bin" ]; then
       mkdir "$HOME/bin"
     fi
     echo "created bin folder"
    createLauncher() {
     OUTPUT="$(gsettings get $SCHEMA $KEY | awk -v file="$DESKFILE" -v sq="'"  '{ sub(/\]/,""); print  $0","sq"application://"file sq "]"  }')" ;
     gsettings set $SCHEMA $KEY "$OUTPUT" ;
     echo "Launcher for Dimmer created"
    createScriptFile() {
     touch "$SCRIPTFILE"
     chmod 755 "$SCRIPTFILE"
     echo "Created script file. Please copy over the code to \"$SCRIPTFILE\""
    createDeskFile() {
     printf "[Desktop Entry]\nName=Dimmer\nExec=%s\nType=Application\nTerminal=false" "$SCRIPTFILE" > "$DESKFILE"
    createBinFolder
    createScriptFile
    createDeskFile
    createLauncher
  5. Make the file executable and start the setup script
    chmod 755 ~/bin/setup.sh && ~/bin/setup.sh
    That script will create bin folder and blank Dimmer.sh file.
  6. Edit the file Dimmer.sh
    gedit ~/bin/Dimmer.sh
  7. Copy the code below, save and close the editor
    #!/bin/sh
    # Name: backlightscript
    # Author: Serg Kolo
    # Date: March 2 , 2015
    # Description: Simple script to change screen brightness using xrandr
    # uncomment this for debugging as needed
    # set -x
    NEWVAL=$( zenity --scale --min-value=0 --max-value=7 --text="Enter number between 0 and 7" ) && brightness=$(($NEWVAL+2))
    if [ "$NEWVAL" != "" ]; then
        xrandr --output "$( xrandr | awk '$2=="connected" {print $1}')" --brightness 0.$brightness
    fi
Now you should be able to double click on the launcher and get that dimmer app working.
A.B.
  • 92,125
If you edit the file /etc/default/grub and change the line:
GRUB_CMDLINE_LINUX=""
to
GRUB_CMDLINE_LINUX="acpi_backlight=vendor"
and then run
sudo update-grub
and reboot, you should have the ability to lower the screen backlight to completely black.
mchid
  • 44,904
  • 102
  • 162
