Whenever I install an application using sudo apt-get install application, I am getting the following error in Ubuntu 14.04 LTS. Even though I get the error, the installation of the applcation I try to install succeeds. How to I fix these errors?
Setting up gconf2 (3.2.6-0ubuntu2) ...
/var/lib/dpkg/info/gconf2.postinst: line 81: gconf-schemas: command not found
dpkg: error processing package gconf2 (--configure):
 subprocess installed post-installation script returned error exit status 127
dpkg: dependency problems prevent configuration of libgnomevfs2-common:
 libgnomevfs2-common depends on gconf2 (>= 2.28.1-2); however:
  Package gconf2 is not configured yet.
dpkg: error processing package libgnomevfs2-common (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libgnomevfs2-0:amd64:
 libgnomevfs2-0:amd64 depends on libgnomevfs2-common (>= 1:2.24); however:
  Package libgnomevfs2-common is not configured yet.
 libgnomevfs2-0:amd64 depends on libgnomevfs2-common (<< 1:2.25); however:
dpkg: error processing package libgnomevfs2-0:amd64 (--configure):
dpkg: dependency problems prevent configuration of libgnome2-common:
 libgnome2-common depends on gconf2 (>= 2.28.1-2); however:
  Package gconf2 isNo apport report written because the error message indicates its a followup error from a previous failure.
     No apport report written because MaxReports is reached already
                            not configured yet.
dpkg: error processing package libgnome2-common (--configure):
dpkg: dependency problems prevent configuration of libgnome2-0:amd64:
 libgnome2-0:amd64 depends on libgnomevfs2-0 (>= 1:2.17.90); however:
  Package libgnomevfs2-0:amd64 is not configured yet.
 libgnome2-0:amd64 depends on libgnome2-common (>= 2.32); however:
  Package libgnome2-common is not configured yet.
 libgnome2-0:amd64 depends on libgnome2-common (<< 2.33); however:
dpkg: error processing package libgnome2-0:amd64 (--configure):
dpkg: dependency problems prevent configuration of libbonoboui2-0:amd64:
 libbonoboui2-0:amd64 depends on libgnome2-0 (>= 2.17.3); however:
  Package libgnome2-0:amd64 is not configured yet.
dpkg: error processing package libbonoboui2-0:amd64 (--configure):
dpkg: dependency problems prevent configuration of libgnomeui-0:amd64:
 libgnomeui-0:amd64 depends on libbonoboui2-0 (>= 2.15.1); however:
  Package libbonoboui2-0:amd64 is not configured yet.
 libgnomeui-0:amd64 depends on libgnome2-0 (>= 2.17.3); however:
 libgnomeui-0:amd64 depends on libgnomevfs2-0 (>= 1:2.17.90); however:
dpkg: error processing package libgnomeui-0:amd64 (--configure):
Setting up doc-base (0.10.5) ...
/var/lib/dpkg/info/doc-base.postinst: line 33: install-docs: command not found
        dpkg: error processing package doc-base (--configure):
dpkg: dependency problems prevent configuration of libgnome-vfs2.0-cil:
 libgnome-vfs2.0-cil depends on libgnomevfs2-0 (>= 1:2.17.90); however:
dpkg: error processing package libgnome-vfs2.0-cil (--configure):
dpkg: dependency problems prevent configuration of libgnome2.24-cil:
 libgnome2.24-cil depends on libgnome-vfs2.0-cil (= 2.24.2-3); however:
  Package libgnome-vfs2.0-cil is not configured yet.
 libgnome2.24-cil depends on libgnome2-0 (>= 2.17.3); however:
 libgnome2.24-cil depends on libgnomeui-0 (>= 2.22.0); however:
  Package libgnomeui-0:amd64 is not configured yet.
dpkg: error processing package libgnome2.24-cil (--configure):
Setting up mono-runtime-common (3.2.8+dfsg-4ubuntu1.1) ...
/var/lib/dpkg/info/mono-runtime-common.postinst: line 4: update-binfmts: command not found
           dpkg: error processing package mono-runtime-common (--configure):
dpkg: dependency problems prevent configuration of pidgin:
 pidgin depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing package pidgin (--configure):
Setting up xrdp (0.6.0-1) ...
adduser: The user `xrdp' already exists. Exiting.
                                                              dpkg: error processing package xrdp (--configure):
Setting up rabbitmq-server (3.2.4-1) ...
/var/lib/dpkg/info/rabbitmq-server.postinst: line 59: update-rc.d: command not found
                                                              dpkg: error processing package rabbitmq-server (--configure):
Setting up htop (1.0.3-1) ...
dpkg: dependency problems prevent configuration of libgnome2-bin:
 libgnome2-bin depends on libgnome2-0 (>= 2.17.3); however:
dpkg: error processing package libgnome2-bin (--configure):
                                                              Processing triggers for menu (2.1.46ubuntu1) ...
 gconf2
 libgnomevfs2-common
 libgnome2-common
 libgnome2-0:amd64
 libgnomeui-0:amd64
 doc-base
 libgnome-vfs2.0-cil
 libgnome2.24-cil
 mono-runtime-common
 pidgin
 xrdp
 rabbitmq-server
 libgnome2-bin
Output of
sudo dpkg --configure -a
$ sudo dpkg --configure -a
 doc-base
 mono-runtime-common
 xrdp
 rabbitmq-server
 gconf2
 libgnomevfs2-common
 libgnome2-common
 pidgin
 libgnome-vfs2.0-cil
 libgnome2-0:amd64
 libgnomeui-0:amd64
 libgnome2.24-cil
 libgnome2-bin
so lets see what package contains the missing gconf-schemas
apt-file search gconf-schemas
shows us
gconf2: /usr/sbin/gconf-schemas
gconf2: /usr/share/man/man8/gconf-schemas.8.gz
so just install it
sudo apt-get install gconf2
sudo apt-get remove xrdp
worked for me.
Vivek
