Does anyone has a hint how to install new Ricoh SP 213w printer? Im not able to find a ppd file but I got a .plc file from Ricoh containing some information about the machine. Is there a possibiliy to make a use of it?
Thanks in advance
frank
Update:
Printers -> Add -> Select the printer from the network -> select "Generic" -> "PCL 5e"
makes the printer print something reasonable, though the margins dont seem right.
Solution:
selecting "Generic" -> "PCL 6/PCL XL" seems to work better.
The only one actually working for me is the Generic PCL Laser Printer (grayscale), the other ones (Pcl5/6) used to work not any more.
I added the printer via its IP Address and chose the Generic" -> "PCL 6/PCL XL LF CUPS+Gutenberg Driver.(a slight change to the above driver) The Testpage describes the fitting PPD as STP01497.PPD Hope that helps.
Bastian
