Hi i am intend to connect phpMyAdmin, i have install XAMPP but i change the port using this guide
Cannot start XAMPP on Ubuntu 11.10
I use this URL to enter phpMyAdmin http://localhost:2145/phpmyadmin but get the following error
phpMyAdmin tried to connect to the MySQL server, and the server rejected the connection. You should check the host, username and password in your configuration and make sure that they correspond to the information given by the administrator of the MySQL server.
my confic.inc.php is:
$cfg['Servers'][$i]['auth_type'] = 'config';
$cfg['Servers'][$i]['user'] = 'root';
$cfg['Servers'][$i]['password'] = '';
$cfg['Servers'][$i]['host'] = 'localhost:2145';
$cfg['Servers'][$i]['connect_type'] = 'cookie';
$cfg['Servers'][$i]['compress'] = false;
$cfg['Servers'][$i]['AllowNoPassword'] = true;
/* User used to manipulate with storage */
// $cfg['Servers'][$i]['controlhost'] = '';
// $cfg['Servers'][$i]['controlport'] = '';
$cfg['Servers'][$i]['controluser'] = '';
$cfg['Servers'][$i]['controlpass'] = '';
thanks for the help
edit
this change resolve the mistake for me
$cfg['Servers'][$i]['auth_type'] = 'cookie';
/* Server parameters */
$cfg['Servers'][$i]['host'] = 'localhost';
$cfg['Servers'][$i]['connect_type'] = 'tcp';
Is necessary also stop the mysql and start the Xampp
sudo service mysql stop
/opt/lampp/lampp start
