On the previous versions the default screen brightness was perfect for me but on 11.10 the default brightness is killing my eye.
I have changed the brightness like this level
but after restarting and every login/logout it returns to default 100%.
Achu
  • 21,407
It was a bug on kernel 3.0.0-12-generic and i report it on launchpad
https://bugs.launchpad.net/ubuntu/+source/gnome-power-manager/+bug/875061
another report i linked to it:
https://bugs.launchpad.net/ubuntu/+source/gnome-control-center/+bug/870805
The suggested solution was to upgrade to 3.1. So, I installed kernel 3.1.0-030100-generic and the problem fixed.
Achu
  • 21,407
From Ubuntu 10.04 to 11.10 I can not change my screen brightness. I use an Acer laptop with VGA Intel HD graphic 3000, and I think this is because my laptop (I tried to update BIOS two or three times so I think that make problems)
I must use xbrightness to fix my problem. You can try to install this package.
It requires some packages like: xutils-dev, libxxf86vm-dev, libxaw7-dev. After installation finish. You can change the brightness by run for example:
$ xbrightness 50000
You can read more on the man page or home site of xbrightness.
You can use this program while waiting for the bug fixed.
neo0
  • 352
Maybe you can try Ishans Python script: http://blog.ishans.info/2011/09/25/set-brightness-automatically-at-the-startup-in-linux/
This stores the current brighness-Information until the next boot.
NaN
  • 1,435
