I play Minecraft on my computer, and whenever I press F3, it says "Gallium 0.4 on NV98" I looked up what this means, and found out that it is a default graphics driver. So, I looked around for how to install the nvidia drivers for my computer, so I ran the command sudo apt-get install nvidia-current. After doing this, when starting Minecraft again, a screen would quickly pop up twice, then it would crash with the following error log:
Picked up JAVA_TOOL_OPTIONS: -javaagent:/usr/share/java/jayatanaag.jar
[15:17:20] [Client thread/INFO]: Setting user: XXXXXXXX
[15:17:20] [Client thread/INFO]: (Session ID is token:XXXXXXXXXXXXXXXXXX)
[15:17:22] [Client thread/INFO]: LWJGL Version: 2.9.4
Xlib: extension "NV-GLX" missing on display ":0".
[15:17:23] [Client thread/ERROR]: Couldn't set pixel format
org.lwjgl.LWJGLException: X Error - disp: 0x7fbce86da1d0 serial: 81 error: BadValue (integer parameter out of range for operation) request_code: 155 minor_code: 24
at org.lwjgl.opengl.LinuxDisplay.globalErrorHandler(LinuxDisplay.java:320) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.opengl.LinuxContextImplementation.nCreate(Native Method) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.opengl.LinuxContextImplementation.create(LinuxContextImplementation.java:51) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.opengl.ContextGL.<init>(ContextGL.java:132) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.opengl.Display.create(Display.java:850) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.opengl.Display.create(Display.java:757) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at ave.ap(SourceFile:521) [1.8.8.jar:?]
at ave.am(SourceFile:363) [1.8.8.jar:?]
at ave.a(SourceFile:310) [1.8.8.jar:?]
at net.minecraft.client.main.Main.main(SourceFile:124) [1.8.8.jar:?]
---- Minecraft Crash Report ----
// There are four lights!
Time: 8/19/15 3:17 PM
Description: Initializing game
org.lwjgl.LWJGLException: X Error - disp: 0x7fbce86da1d0 serial: 134 error: BadValue (integer parameter out of range for operation) request_code: 155 minor_code: 24
at org.lwjgl.opengl.Display.create(Display.java:739)
at ave.ap(SourceFile:534)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.8.8
Operating System: Linux (amd64) version 3.19.0-15-generic
Java Version: 1.7.0_79, Oracle Corporation
Java VM Version: OpenJDK 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 72926576 bytes (69 MB) / 176979968 bytes (168 MB) up to 1060372480 bytes (1011 MB)
JVM Flags: 5 total; -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.8.8
LWJGL: 2.9.4
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: Yes
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs:
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
CPU: <unknown>
#@!@# Game crashed! Crash report saved to: #@!@# /home/mayatta65/.minecraft/crash-reports/crash-2015-08-19_15.17.24-client.txt
[15:17:24] [Client Shutdown Thread/INFO]: Stopping server
After doing that, I had to uninstall the packages so that it would fall back to the Gallium 0.4 driver. How can I install the Nvidia drivers and get Minecraft to work?
