I cannot install ligbfortran3. What is the best way to solve this ? I want to keep my install as standard as possible. Thank you.
root@arau:~# apt-get --simulate install libgfortran3
Reading package lists... Done
Building dependency tree
 libgfortran3 : Depends: gcc-4.8-base (= 4.8.2-19ubuntu1) but 4.8.4-2ubuntu1~14.04 is to be installed
root@arau:~#
root@arau:~#
root@arau:~#
root@arau:~#
root@arau:~# aptitude show gcc-4.8-base
Package: gcc-4.8-base
State: installed
Automatically installed: no
Multi-Arch: same
Version: 4.8.4-2ubuntu1~14.04
Priority: required
Section: libs
Maintainer: Ubuntu Core developers <ubuntu-devel-discuss@lists.ubuntu.com>
Architecture: amd64
Uncompressed Size: 222 k
Breaks: dehydra (<= 0.9.hg20110609-2), dehydra (<= 0.9.hg20110609-2), gcc-4.4-base (< 4.4.7), gcc-4.4-base (< 4.4.7), gcc-4.7-base (< 4.7.3),
        gcc-4.7-base (< 4.7.3), gcj-4.4-base (< 4.4.6-9~), gcj-4.4-base (< 4.4.6-9~), gcj-4.6-base (< 4.6.1-4~), gcj-4.6-base (< 4.6.1-4~),
        gnat-4.4-base (< 4.4.6-3~), gnat-4.4-base (< 4.4.6-3~), gnat-4.6 (< 4.6.1-5~), gnat-4.6 (< 4.6.1-5~), gcc-4.8-base (!= 4.8.4-2ubuntu1~14.04)
Replaces: gcc-4.8-base (< 4.8.4-2ubuntu1~14.04)
Description: GCC, the GNU Compiler Collection (base package)
 This package contains files common to all languages and libraries contained in the GNU Compiler Collection (GCC).
Homepage: http://gcc.gnu.org/
My sources.list is standard:
root@arau:~# cat /etc/apt/sources.list
# deb cdrom:[Ubuntu 14.04.1 LTS _Trusty Tahr_ - Release amd64 (20140722.2)]/ trusty main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://fr.archive.ubuntu.com/ubuntu/ trusty main restricted
deb-src http://fr.archive.ubuntu.com/ubuntu/ trusty main restricted
## Major bug fix updates produced after the final release of the
## distribution.
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://fr.archive.ubuntu.com/ubuntu/ trusty universe
deb-src http://fr.archive.ubuntu.com/ubuntu/ trusty universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://fr.archive.ubuntu.com/ubuntu/ trusty multiverse
deb-src http://fr.archive.ubuntu.com/ubuntu/ trusty multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu trusty partner
# deb-src http://archive.canonical.com/ubuntu trusty partner
## This software is not part of Ubuntu, but is offered by third-party
## developers who want to ship their latest software.
deb http://extras.ubuntu.com/ubuntu trusty main
deb-src http://extras.ubuntu.com/ubuntu trusty main
------------- EDIT 1
root@arau:~# apt-cache policy gcc-4.8-base
gcc-4.8-base:
  Installed: 4.8.4-2ubuntu1~14.04
  Candidate: 4.8.4-2ubuntu1~14.04
  Version table:
 *** 4.8.4-2ubuntu1~14.04 0
        100 /var/lib/dpkg/status
     4.8.2-19ubuntu1 0
        500 http://fr.archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
------------- EDIT 2
root@arau:~# dpkg -l | grep gcc
ii  gcc                                                   4:4.8.2-1ubuntu6                                    amd64        GNU C compiler
ii  gcc-4.8                                               4.8.4-2ubuntu1~14.04                                amd64        GNU C compiler
ii  gcc-4.8-base:amd64                                    4.8.4-2ubuntu1~14.04                                amd64        GCC, the GNU Compiler Collection (base package)
ii  gcc-4.9-base:amd64                                    4.9.1-0ubuntu1                                      amd64        GCC, the GNU Compiler Collection (base package)
ii  libgcc-4.8-dev:amd64                                  4.8.4-2ubuntu1~14.04                                amd64        GCC support library (development files)
ii  libgcc1:amd64                                         1:4.9.1-0ubuntu1                                    amd64        GCC support library
------------- EDIT 3
actually "aptitude" solved my problem, thanks guys.
root@arau:~# aptitude install libgfortran3
The following NEW packages will be installed:
  libgfortran3{b}
0 packages upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 250 kB of archives. After unpacking 1 230 kB will be used.
 libgfortran3 : Depends: gcc-4.8-base (= 4.8.2-19ubuntu1) but 4.8.4-2ubuntu1~14.04 is installed.
Internal error: found 2 (choice -> promotion) mappings for a single choice.
The following actions will resolve these dependencies:
     Keep the following packages at their current version:
1)     libgfortran3 [Not Installed]
Accept this solution? [Y/n/q/?] n
      Downgrade the following packages:
1)      cpp-4.8 [4.8.4-2ubuntu1~14.04 (now) -> 4.8.2-19ubuntu1 (trusty)]
2)      gcc-4.8 [4.8.4-2ubuntu1~14.04 (now) -> 4.8.2-19ubuntu1 (trusty)]
3)      gcc-4.8-base [4.8.4-2ubuntu1~14.04 (now) -> 4.8.2-19ubuntu1 (trusty)]
4)      libasan0 [4.8.4-2ubuntu1~14.04 (now) -> 4.8.2-19ubuntu1 (trusty)]
5)      libatomic1 [4.8.4-2ubuntu1~14.04 (now) -> 4.8.2-19ubuntu1 (trusty)]
6)      libgcc-4.8-dev [4.8.4-2ubuntu1~14.04 (now) -> 4.8.2-19ubuntu1 (trusty)]
7)      libgomp1 [4.8.4-2ubuntu1~14.04 (now) -> 4.8.2-19ubuntu1 (trusty)]
8)      libitm1 [4.8.4-2ubuntu1~14.04 (now) -> 4.8.2-19ubuntu1 (trusty)]
9)      libquadmath0 [4.8.4-2ubuntu1~14.04 (now) -> 4.8.2-19ubuntu1 (trusty)]
10)     libstdc++6 [4.8.4-2ubuntu1~14.04 (now) -> 4.8.2-19ubuntu1 (trusty)]
11)     libtsan0 [4.8.4-2ubuntu1~14.04 (now) -> 4.8.2-19ubuntu1 (trusty)]
Accept this solution? [Y/n/q/?] y
Bob Yoplait
  • 1,904
Do you really need the 3 version? 4.8 is the current one on my trusty system. If you have an old executable referring to such an old version, try just adding a link to the 4 version. That might work, unless the old exe is using obsolete functions.
Assuming you really need the 3 library, maybe one way is to install the 32 bit versions to avoid conflict with the 64 bit versions of the library.
Try looking at the still supported 12.04.5 release to see which version it uses, but assume it's at 4 too. Any release with the 3 fortran as standard will not be currently supported.
You could remove the conflicting package (probably a few), try installing the lib3, see what new complaints are made, delete those, until finally there are no conflicts. Then you would need to supply sources for the required versions, getting messy here, then if you can successfully get things consistent, freeze it so no further updates will happen on those packages. Certainly not your desired standard install.
The best approach I can see is to treat the lib3 stuff as a cross compiler. Install what you need locally, and don't touch the regular system.
ubfan1
  • 19,049
