I've recently updated to Oneiric. I've noticed though that some of the indicators that are supposed to open a window when you double click it no longer works. In fact you can only left click and or right click to open a menu. You should to be able to double click the icon to open up the programs main window. Now I can no longer access some of the stuff easily that I used to before. Example KeePassX.
Normally when you run KeePassX it's hidden and minimized to the Indicator (notify bar). You had to double click on it and type the unlock code to get the full window. Now I can't even do that as the only options are the global unlock and exit from the menu that pops up.
There are other indicators that do the same thing. The Skype indicator used to open the window when you double clicked it. Now you have to select 'Activate" from the menu window.
I don't know why this was changed or is a bug. I'm hoping there is a way to fix this problem as there are several indicators and applications I use that use indicators that no longer work now. Again I only have access to their menu's but can no longer double-click.
Any help would be great
