14
Normally I would just do:
sudo adduser anewuser
and then provide the initial password.
However in Ubuntu Phone I get:
passwd: Authentication token manipulation error
passwd: password unchanged
What can I do?
CaesarS
  • 363
Error passwd: Authentication token manipulation error occurs generally in following scenario:
  • File system mounted as read-only.
  • Incorrect Permissions on system files.
In your case, as you're working with Ubuntu Touch, I'm guessing that your system is mounted in Read-Only mode, as this is general security feature of any Mobile Phone OS to reduce risk of overwriting System Files by any other services/application accidentally or purposefully.
Solution could be remount file-system in Read/Write mode, and also by checking File-permissions & Correct it if required to make sure you're changes will make through!
Novice
  • 550
Ubuntu Touch currently is not designed for a multi-user use case.
