I have problems with apt-get update once in a while. This error is shown sometimes I try to run this command:
sudo apt-get update
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
What's going on? I'd like to know the problem and solve it. It's solved once I restart my pc though, but I would like to know what is this error. Thanks.
That usually means you have another program that uses apt open. It could be Ubuntu Software Center, the program synaptic, or even another terminal that's running some apt-get ... function.
Try closing all programs that are used to manage software and trying again.
You could find out which program has the lock locked:
sudo lsof /var/lib/apt/lists/lock
waltinator
  • 37,856
