23
I'm a total newbie in Linux specially Ubuntu, I'm just asking on how to format a USB using Ubuntu terminal. Hope you can help me thanks!
warrior
  • 231
  • First, you have to find out which device (/dev/sd??) your USB stick is. Therefore look at the output of
    sudo fdisk -l
  • After that unmount the device/partition (if necessary) by running
    sudo umount /dev/sd??
    Make sure you replaced ?? with the correct device/partition name from the previous output.
  • To format The partition as FAT32 use
    sudo mkdosfs -F 32 -I /dev/sd??
    Again replace ?? with your respective letters.
Be careful that if you enter the wrong device name, you might also accidentally format your hard disk!
You can also do
    sudo -s
and you don't have to put "sudo" in front of everything!
L. Barzic
  • 469
