I upgraded to 11.10 yesterday.
My Nautilus started to crash on load, looks like a known bug with remote terminal plugin nautilus exiting with segmentation fault after upgrade.
So I decided to uninstall it, but that was the beginning of my nightmare - my root password is changed.
Yes, I type in the right password, but auth fails!
I don't know what to do, I can't auth as root, which means I can't install/uninstall packages.
umpirsky@umpirsky:~$ su
Password:
su: Authentication failure
Any idea? Please help.
UPDATE: I removed default keyring, but problem resists.
rm ~/.gnome2/keyrings/default.keyring
umpirsky
  • 3,852
The root account is disabled by default. A safer way to perform super-user actions is using the sudo command followed by your command. Example : sudo apt-get install clementine.
But if you really want to borrow the super-user account for a while, use sudo su. You can set the root account password there with passwd command. Example:
##Enter your account's password here##
nits@nits-workstation:~$ sudo su
[sudo] password for nits:
root@nits-workstation:/home/nits# passwd
Enter new UNIX password:
Retype new UNIX password:
passwd: password updated successfully
root@nits-workstation:/home/nits# exit
exit
##once the password is set, log-in to the root account with the password you just set##
Password:
