I'm pretty new to linux and have only had a little exposure to it. From what I've seen I really like it.
What I've done is I have a laptop from my employer that I take with me on business trips. There isn't administrator rights on my account so I can't install much of anything. I'm an avid gamer without a gaming laptop and it kills me when I go on a trip and can't game. I had the idea to install ubuntu to my external hard drive since I can load steam and play my games on the go.
Everything was working great and I have my external hard drive booting into Ubuntu and thought I was well on my way to this idea working....
Problem is that it looks like my Windows partition (the internal hdd) won't boot unless my external hard drive is attached so it can use the bootloader (GRUB maybe?) from the external hdd.
Any help would be awesome. I don't really want to have to take my external drive in to my office just to select the windows partition to boot and i certainly dont want to ask our IT for help. Is it possible to directly boot into windows when the external hdd isn't connected and into the external hdd when it is connected?
First you must boot into Ubuntu and run
sudo grub-install /dev/sda
and then you need to change your BIOS settings to boot to the internal drive first. That will put the GRUB bootloader on the internal drive.
On the other hand, you can just use your BIOS boot menu to select the internal drive during bootup.
Daniel
  • 3,626
  • 24
  • 46
If you have a CD/DVD of your Windows (The clean solution) :
  1. Boot from Windows CD/DVD and choose “Repair” when it shows up.
  2. Choose Command Prompt on the resulting screen and run the following two commands:
    bootrec /fixmbr bootrec /fixboot
  3. Remove the CD/DVD and you should boot straight into Windows
If you don't have the CD/DVD then use Ubuntu:
  1. if internet connectivity available, open a terminal and run these commands:
    sudo apt-get install lilo sudo lilo -M /dev/sda mbr
  2. If no Internet connection:
    Recent versions of Ubuntu include the file /usr/lib/syslinux/mbr.bin which is 440 bytes in length and simply needs to be written to the beginning of the mbr with this terminal command. WARNING! Be very careful with this command and check for typos before running it.
    sudo dd if=/usr/lib/syslinux/mbr.bin of=/dev/sda
  3. Now reboot, remove external HDD and you should reboot straight into Windows.
