I get this error when launching qtconsole.
I already installed:
sudo apt-get install libzmq-dev
sudo pip install pyzmq
sudo pip install pygments
sudo apt-get install libqt4-core libqt4-gui libqt4-dev
Can anyone help me figure out what's going on? I am quite new to this system and I am probably missing something really basic...thank you
david@Hyperion:~$ ipython qtconsole
Traceback (most recent call last):
File "/usr/local/bin/ipython", line 9, in <module>
load_entry_point('ipython==4.1.0.dev0', 'console_scripts', 'ipython')()
File "/usr/local/lib/python2.7/dist-packages/ipython-4.1.0.dev0-py2.7.egg/IPython/__init__.py", line 118, in start_ipython
return launch_new_instance(argv=argv, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/traitlets/config/application.py", line 591, in launch_instance
app.initialize(argv)
File "<string>", line 2, in initialize
File "/usr/local/lib/python2.7/dist-packages/traitlets/config/application.py", line 75, in catch_config_error
return method(app, *args, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/ipython-4.1.0.dev0-py2.7.egg/IPython/terminal/ipapp.py", line 305, in initialize
super(TerminalIPythonApp, self).initialize(argv)
File "/usr/local/lib/python2.7/dist-packages/ipython-4.1.0.dev0-py2.7.egg/IPython/core/application.py", line 386, in initialize
self.parse_command_line(argv)
File "/usr/local/lib/python2.7/dist-packages/ipython-4.1.0.dev0-py2.7.egg/IPython/terminal/ipapp.py", line 300, in parse_command_line
return super(TerminalIPythonApp, self).parse_command_line(argv)
File "<string>", line 2, in parse_command_line
File "/usr/local/lib/python2.7/dist-packages/traitlets/config/application.py", line 487, in parse_command_line
return self.initialize_subcommand(subc, subargv)
File "<string>", line 2, in initialize_subcommand
File "/usr/local/lib/python2.7/dist-packages/traitlets/config/application.py", line 418, in initialize_subcommand
subapp = import_item(subapp)
File "/usr/local/lib/python2.7/dist-packages/ipython_genutils/importstring.py", line 31, in import_item
module = __import__(package, fromlist=[obj])
ImportError: No module named qtconsole.qtconsoleapp
