I've noticed that my laptop has been running hotter than it should be as well as output similar to the following from dmesg around when bbswitch should be shutting down my Nvidia GPU
[ 5775.721636] NVLINK: Unregistered the Nvlink Core, major device number 248
[ 5775.721996] [drm] Module unloaded
[ 5775.747097] bbswitch: disabling discrete graphics
[ 5775.747109] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20141107/nsarguments-95)
[ 5775.761965] pci 0000:01:00.0: Refused to change power state, currently in D0
Based on this, it appears that bbswitch is failing to actually turn off the GPU
For reference, output of lspci | grep 01:00
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 635M] (rev ff)
Bumblebee is working correctly aside from this issue. I'm using Ubuntu 15.04.
