I have 2 fairly new SATA hard drives that I'm moving to a new machine. One was the boot drive, the other had all 'My Stuff' on it. Both drives were installed under Ubuntu 12.04
I need to copy the contents of the 'My Stuff' drive to the other drive.
So new parts (i5, Asus Z97e Mobo, Asus GTX 970 & RAM)
I couldn't remember which was the boot drive, & accidentally installed Ubuntu 14.04 to the 'My Stuff' drive instead of the boot drive. Not a problem, it made a new partition & I could still access everything.
So I removed the 'My Stuff' drive from the machine, leaving just the original boot drive, which I wiped & installed Win10 on.
I then added the 'My Stuff' drive back in, but could not boot from it. Windows could not read it, disk manager showed the partitions but I didn't do anything.
I then ran Ubuntu 14.04 from a flash drive, hoping to access the 'My Stuff' drive & copy the contents over to the (Windows) boot drive. BUT I can't access any of the 'My Stuff' drive; I apparently don't have the necessary permissions. Apparently the owner is the other drive.
I know about backing up data I want to keep, it was backed up, a full copy was on the other drive (which is now wiped), & most of it was also backed up to a 12 year old PATA drive (which I have got working via USB caddy) but it is completely full with no room for some of the data I wanted to keep.
I also tried putting the 'My Stuff' drive into the USB caddy (which can do PATA & SATA) & tried under Win10 (from HDD) & also tried from Ubuntu (from flash drive) but I just cant access the drive. No permission under Ubuntu & Win10 just cant see it.
I eventually want to run dual boot Win10 & Ubuntu 14.04, but I need to copy some of the contents of the 'My Stuff' drive to the other drive first.
Zanna
  • 72,312
Try to copy your files as root of your Live-Ubuntu-drive
Open a terminal and type
sudo -i
nautilus
to open the file manager as root. When done, in the terminal type
exit
to drop privileges.
Zanna
  • 72,312
pagdot
  • 174
