If you are using gpg-agent all passwords (including the master password) are stored/saved in ~/.password-store.
From the "pass" website:
There will be a nice password input dialog using the standard gpg-agent (which can be configured to stay authenticated for several minutes), since all passwords are encrypted.
gpg-agent manual page:
--default-cache-ttl n  Set the time a cache entry is valid to n seconds.
The default is 600 seconds.
--default-cache-ttl-ssh n Set the time a cache entry used for SSH keys
The default is 1800 seconds.
--max-cache-ttl n  Set the maximum time a cache entry is valid to n seconds.
After this time a cache entry will be expired even if it has been accessed recently.
The default is 2 hours (7200 seconds).
--max-cache-ttl-ssh n Set the maximum time a cache entry used for SSH keys is valid
to n seconds. After this time a cache entry will be expired even if
and ...
gpg-agent.conf
This is the standard configuration file read by gpg-agent on
      startup. It may contain any valid long option; the leading
      two dashes may not be entered and the option may not be abbreviated.
      This file is also read after a SIGHUP however only a few
      options will actually have an effect. This default name may be
      changed on the command line (see: [option --options]).
      You should backup this file.
This will only be read if you actually use gpg-agent. If it is "seahorse" (the default in Ubuntu) gpg-agent is ignored).
So you can put any of the 4 parameters in the configuration file with a time in seconds to keep password valid (that includes the master password since that is also stored in ). To release the passwords you can use echo RELOADAGENT | gpg-connect-agent (see the manual for more options).
