So i have this script here Remove Audio Streams of videos - recursively without converting audio or video with FFMPEG But the subtitles part doesn't work. Currently I have tried a few variations of
export FLAGS='-sub_charenc CP1252 -i "${1%\.*}".srt -vcodec copy -acodec copy'
and
find "$TRANSCODEDIR"/* -type f -name "*.mkv" -exec bash -c 'ffmpeg -i "$1" "$FLAGS" "${1%\.*}".mkv ' _ {} \;
But I am getting errors like movie.mkv.srt does not exist or atleast one output file must be specified, and others, I am going to trial and error again and keep notes of what errors I get depending on what variation, but any help pointing me in the right direction is appreciated.
What code is supposed to do
File Tree Example
Movie.mkv Movie2.mkv Movie.srt Movie2.srt
It should add the correct srt to the correct mkv.
As it stands the error i get is that
Unrecognized option 'sub_charenc CP1252 -i "${1%\.*}".srt -vcodec copy -acodec c        opy'.
FreeSoftwareServers
  • 1,129
  • 14
  • 32
  1. Create a script with the name export_flags
    #!/bin/bash
    srt_file_name="${1%\.*}".srt
    if [ -f "$srt_file_name" ]; then
            FLAGS="-i $srt_file_name -sub_charenc CP1252 -vcodec copy -acodec copy"
    else
            FLAGS=""
    fi
    export FLAGS="$FLAGS"
  2. Make it executable
    chmod +x export_flags
  3. Start a test with
    source export_flags your_mkv
    echo $FLAGS
    E.G.
    source export_flags SampleVideo_1080x720_1mb.mkv
    echo $FLAGS
    the output should be something like this
    -i SampleVideo_1080x720_1mb.srt -sub_charenc CP1252 -vcodec copy -acodec copy
  4. Use four find command
    find . -type f -name "*.mkv" -exec bash -c 'source export_flags "$1"; ffmpeg -i "$1" $FLAGS "${1%\.*}".mkv' _ {} \;
    In my case I have this
    ffmpeg version 2.5.8-0ubuntu0.15.04.1 Copyright (c) 2000-2015 the FFmpeg developers
      built with gcc 4.9.2 (Ubuntu 4.9.2-10ubuntu13)
      configuration: --prefix=/usr --extra-version=0ubuntu0.15.04.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --shlibdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --enable-shared --disable-stripping --enable-avresample --enable-avisynth --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libschroedinger --enable-libshine --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libwavpack --enable-libwebp --enable-libxvid --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzvbi --enable-libzmq --enable-frei0r --enable-libvpx --enable-libx264 --enable-libsoxr --enable-gnutls --enable-openal --enable-libopencv --enable-librtmp --enable-libx265
      libavutil      54. 15.100 / 54. 15.100
      libavcodec     56. 13.100 / 56. 13.100
      libavformat    56. 15.102 / 56. 15.102
      libavdevice    56.  3.100 / 56.  3.100
      libavfilter     5.  2.103 /  5.  2.103
      libavresample   2.  1.  0 /  2.  1.  0
      libswscale      3.  1.101 /  3.  1.101
      libswresample   1.  1.100 /  1.  1.100
      libpostproc    53.  3.100 / 53.  3.100
    Input #0, matroska,webm, from './SampleVideo_1080x720_1mb.mkv':
      Metadata:
        ENCODER         : Lavf56.15.102
      Duration: 00:00:00.32, start: 0.080000, bitrate: 2642 kb/s
        Stream #0:0: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 50 tbc (default)
        Metadata:
          ENCODER         : Lavc56.13.100 libx264
        Stream #0:1: Audio: vorbis, 48000 Hz, 5.1, fltp (default)
        Metadata:
          ENCODER         : Lavc56.13.100 libvorbis
    Input #1, srt, from './SampleVideo_1080x720_1mb.srt':
      Duration: N/A, bitrate: N/A
        Stream #1:0: Subtitle: subrip
    File './SampleVideo_1080x720_1mb.mkv' already exists. Overwrite ? [y/N]
A.B.
  • 92,125
