31
I'm using Ubuntu 14.04 and I use the Perapera Chinese add-on for Firefox. It worked up to version 39, but now in version 40 it just stopped working. So I tried to downgrade to version 39 following this link, where there are two options:
1) Choose from the list here, but I have no idea which of the 11 subversions should I use.
2) Download the only version suggested in the link above, i.e. this.
I chose the 2nd option, but after decompressing the file, I have a 'Firefox' folder with lots of files and executables that don't run, just give an error message:
XPCOMGlueLoad error for file (...)/firefox/libxul.so:
libXcomposite.so.1: cannot open shared object file: No such file or directory
Couldn't load XPCOM.
There's a 'run-mozilla.sh', but 'bash run-mozilla.sh' gives:
run-mozilla.sh: Cannot execute .
I REALLY would like to use Perapera add-on to study Chinese. So, is there an easy way to downgrade to Firefox 39? Thanks in advance.
Rodrigo
  • 576
You may have two choice to choose for installing method:
  1. Via Mozilla's ftp site (kudos for @Bhikku for sharing the link !). For example we're going to install firefox 50. First, remove any existing version.
    sudo apt-get purge firefox
    Then run following command to download firefox 50 source code, which comes as .tar file.
    wget http://ftp.mozilla.org/pub/firefox/releases/50.0/linux-$(uname -m)/en-US/firefox-50.0.tar.bz2
    Extract the package.
    tar -xjf firefox-50.0.tar.bz2
    Move firefox to /opt directory.
    sudo mv firefox /opt/
    Create symlink in order to set the new firefox as default.
    sudo mv /usr/bin/firefox /usr/bin/firefox_old
    sudo ln -s /opt/firefox/firefox /usr/bin/firefox
  2. Via UbuntuZilla which offer .deb files, to install follow the instruction below.
Remove firefox first :
Run following command to download firefox :
32 Bit
wget http://downloads.sourceforge.net/project/ubuntuzilla/mozilla/apt/pool/main/f/firefox-mozilla-build/firefox-mozilla-build_39.0.3-0ubuntu1_i386.deb
64 Bit
wget sourceforge.net/projects/ubuntuzilla/files/mozilla/apt/pool/main/f/firefox-mozilla-build/firefox-mozilla-build_39.0.3-0ubuntu1_amd64.deb
Install it :
32 Bit
cd Downloads/ && sudo dpkg -i firefox-mozilla-build_39.0.3-0ubuntu1_i386.deb
64 Bit
cd Downloads/ && sudo dpkg -i firefox-mozilla-build_39.0.3-0ubuntu1_amd64.deb
And firefox should run the 39 version
Quote from ubuntuzilla official wiki page :
This is the home of the Ubuntuzilla project, hosts an APT repository with .deb repacks of the latest official release versions of Mozilla Firefox, Mozilla SeaMonkey, and Mozilla Thunderbird.
Liso
  • 15,677
21
In a terminal run:
apt-cache show firefox | grep Version
You will get a list of available versions like in the list below:
Version: 54.0+build3-0ubuntu0.16.04.1
Version: 45.0.2+build1-0ubuntu1
Install the desired version with:
sudo apt-get install firefox=45.0.2+build1-0ubuntu1
Prevent Ubuntu from upgrading to the latest version:
sudo apt-mark hold firefox
10
While the normal repository often only contains the latest version for older Ubuntu releases, you may be able to find the previous version with the help of Google.
Generalizing from this blog about Firefox 43 on Ubuntu 12.04, you could search for
https://www.google.com/search?q=firefox+$FF_VERSION+$UBUNTU_VERSION+deb
Then
sudo apt-get remove firefox
wget "$URL"
sudo dpkg -i "firefox-....deb"
The drawback is that you won't get security upgrades for Firefox, so this is only a temporary solution.
mivk
  • 5,811
This is how I downgraded to Firefox 50 version from version 57.
  1. Go to Firefox Release archive and download a suitable version for you.
  2. Press Ctrl+Alt+T to open the terminal and copy-paste this code:
    sudo apt remove firefox
    To uninstall Firefox current version.
  3. Now, go to the directory where Firefox-.tar.gz( or .tar.gz2) file is kept using the terminal or using file manager. Enter this code( if using the terminal):
    tar -xzf firefox-.tar.gz2
    If using file manager, simply extract the file using the Archive Manager(Look in the context menu).
  4. Open the folder and run the file 'firefox'.
Caution: Don't forget to stop automatic updates in Firefox.
This is the way I did it. Firefox is not installed completely but it still works the way it should. Only the options and the Firefox symbol are not there.
I recommend locking the Firefox in the launcher.
To create a shortcut on the desktop, go to the file and open context menu. Click on 'Make Link'. The file created is to be pasted on the desktop.
Hope this helps!:)
