I was able to create a ext3 partition with out any problems using Gparted and now I am trying to send over a persistence.conf but it fails each time, here is what commands I am running:
 sudo mkdir /mnt/usb
 sudo mount /dev/sdb3 /mnt/usb
 sudo echo "/ union" >> /mnt/usb/persistence.conf
 bash: /mnt/usb/persistence.conf: Permission denied
Does anyone know how to fix this?
miggs97
  • 31
sudo echo "something" > etc never works, better try this sudo sh -c "echo ....", the working command should be like this:
sudo sh -c "echo "/ union" > persistence.conf"
thanhvg
  • 41
This is a clean way of writing files with sudo.
echo "/ union" | sudo tee persistence.conf
Erik
You should use the Bash shell in Sudo mode with -c option to execute the custom shell.
sudo bash -c "echo '/ union' > /mnt/persist/persistence.conf"
Also note that you should properly nest the double quotes.
Another example is:
sudo bash -c "cat /mnt/persist/persistence.conf"
Reference: What's the difference between 'sudo [command]' and 'sudo sh [command]?
RSW
  • 101
